Eagle / RPM / 'Source' cranks - Still SSDB for QC?
#1084268
09/28/11 01:17 PM
09/28/11 01:17 PM
BradH
Are Eagle / RPM / 440 Source cranks still basically the SSDB (Same "Stuff", Different Box) for QC these days? Has anyone of these "budget" cranks reigned in their QC enough to be able to buy one and NOT expect to have to drop more $$$ to have it cut .010" right from the start? EDIT: Let's throw Ohio Crank into this mix, too, since there's a lot of flak about their stuff posted over on SpeedTalk. Also, are K1 Technology's cranks still legitimately "ready to run" in terms of OOB machining (balancing not withstanding)? Seems like the price difference is close to what you'd pay for one of the above brands + a regrind job. Too bad they never offered a 6-bolt 3.75" RB crank (only an 8-bolt version in that stroke).
Re: Eagle / RPM / 'Source' cranks - Still SSDB for QC?
[Re: Irun5snd8th]
#1084272
09/28/11 04:41 PM
09/28/11 04:41 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I have a Eagle and seems to be ok but dont have that many passes on it yet. It didnt have to get reground or balanced. The eagle rods did need a little bit of work.
67' charger 499 RB
10.57 at 127
[Re: PorkyPig]
#1084276
09/28/11 05:45 PM
09/28/11 05:45 PM
dragram440
bigfork mn
OOOOPS! hard to believe it is still running! No it is balanced. I dont know if It came from eagle balanced or if the place the parts store ordered it from balanced it. There is a eagle balance sheet that came with it and all the weights hand writen in and I paid for balanced. The small end of the rod was to small for the .990 pins.
67' charger 499 RB
10.57 at 127
[Re: pittsburghracer]
#1084280
09/28/11 07:51 PM
09/28/11 07:51 PM
BradH
i'll just sit here and
i love that term, "spot on".
That really means " one spot was on "
Kind of like "rust free" really means "you get the rust for free", eh?
[Re: BradH]
#1084281
09/28/11 09:22 PM
09/28/11 09:22 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
Oh boy, just when you thought these threads couldn't get beaten to death any more.
Whatever your here, the varying stories between not having to touch it, to grinding it .010 under should tell you about the consistancy in finish machining quality.
BTW - Although not mentioned in th OP's list, K1 is far better in my book.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: turbobitt]
#1084282
09/28/11 11:58 PM
09/28/11 11:58 PM
BradH
You're on Moparts, right?
BTW, I did mention K1 above, but not in the same list as the other "budget" cranks.
[Re: BradH]
#1084284
09/29/11 03:30 AM
09/29/11 03:30 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Have two 440 source stroker engines, a 400 stroked with the 4.15" (500 cid), and a 440 stroked with a 4.25" (505 cid.) The 400/500" engine is automatic, so I didn't check the hole for the transmission pilot bushing, but on the 4.15" crank it was a hair too tight, but easy to fix, just cleaned it up with the correct drill bit size (I think 15/16"?) The only other issue I had with both kits was the rod side clearance on the #5/#6 rod journal? Just sanded the sides of the rods a few thousandth and it was fine. After reading all the complaints, I really checked over the crank when assembling the 505 engine, and I mic'ed every journal which was right on spec. I also checked the indexing on every throw, and it checked out fine too. The actual crank stroke was 4.252", but was the same on each throw.
[Re: turbobitt]
#1084286
09/29/11 06:56 PM
09/29/11 06:56 PM
dartman366
Mt. Vernon, Ohio
4 years runnin' a Eagle crank in my present smallblock and had to have it ground .010,, mainly because the index was off and some slight taper.
