What to use to pull a Harmonic balancer on a 3.0 v6 #1084189
09/28/11 10:17 AM
09/28/11 10:17 AM
DELAWARE
bee71mopar Offline OP
DELAWARE
Has anyone pulled a harmonic balancer off a 3.0 v6? I went to the local auto parts stores and all they have is the std. Chrysler puller which will not work.It pulls the balancer on the inner part but the ones on a 3.0 v6 is solid. I just tried a 2 claw puller and it started to pull the gear for the timing belt with it...
Re: What to use to pull a Harmonic balancer on a 3.0 v6 [Re: bee71mopar] #1084190
09/28/11 10:23 AM
09/28/11 10:23 AM
The Grand State of Confusion-O...
SKR8PN Offline
SKR8PN  Offline
What year 3.0 is it? Most of the 3.0's that I have ever seen, are not a press fit. They will just slide off with a little persuasion........
Karma has no menu. You get served what you deserve.
Re: What to use to pull a Harmonic balancer on a 3.0 v6 [Re: SKR8PN] #1084191
09/28/11 10:25 AM
09/28/11 10:25 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: What to use to pull a Harmonic balancer on a 3.0 v6 [Re: SKR8PN] #1084192
09/28/11 10:41 AM
09/28/11 10:41 AM
DELAWARE
DELAWARE
Its a 2001 Chrysler Sebring
Re: What to use to pull a Harmonic balancer on a 3.0 v6 [Re: bee71mopar] #1084193
09/28/11 01:01 PM
09/28/11 01:01 PM
DELAWARE
DELAWARE
Ok so why is the sprocket for the timing belt staying with the balancer when pulling on the balancer?
Re: What to use to pull a Harmonic balancer on a 3.0 v6 [Re: bee71mopar] #1084194
09/28/11 01:46 PM
09/28/11 01:46 PM
Boonton USA
74DartSport Offline
74DartSport  Offline
Boonton USA
The timing belt pulley just slides on the nose of the crank, it tends to stick to the pulley via the rollpin rusting a little.
Upholding the 74DartSport� brand everywhere.
Re: What to use to pull a Harmonic balancer on a 3.0 v6 [Re: 74DartSport] #1084195
09/28/11 01:51 PM
09/28/11 01:51 PM
SKR8PN Offline
SKR8PN  Offline
Re: What to use to pull a Harmonic balancer on a 3.0 v6 *DELETED* [Re: SKR8PN] #1084196
09/29/11 12:29 PM
09/29/11 12:29 PM
DELAWARE
DELAWARE
Post deleted by bee71mopar
Re: What to use to pull a Harmonic balancer on a 3.0 v6 [Re: bee71mopar] #1084197
09/29/11 03:59 PM
09/29/11 03:59 PM
DELAWARE
DELAWARE
WOOO HOOOO !!!! I got it with a little penetrent,heat and a hammer.. no rust showing on the back of the balancer but it was on there good. Well now I have an issue and that is when I started it up now it sounds like it jumped timing.. poppping out the exhaust,etc. dont know why because the timing belt never came off the sprocket.Checked the battery and it has 12.22volts so I am letting it charge for now.I hope its not the timing.
Re: Harmonic balancer on a 3.0 v6 *** UPDATE*** [Re: bee71mopar] #1084198
10/09/11 07:20 PM
10/09/11 07:20 PM
DELAWARE
DELAWARE
Now this thing will not run like it should ...Of course it wants to challenge me..lol The two top sprockets are aligned but the crank sprocket ??? HELP with PICTURES..
