Pinhole in the oilpan... easy fixes?
#1084167
09/28/11 09:26 AM
09/28/11 09:26 AM
Posts: 2,536 o
wunderless
o
I recently discovered that I have a pinhole in my oil pan. It is located about 3-4 inches to the left (driver side) of the drain plug. Big enough to leak when warm, small enough that I'm not losing a lot of oil.
I am looking for suggestions on how to repair this without pulling the engine.
It is a 383 in a cuda.
Anyone have some thoughts? Thanks!
But existing is basically all I do.
Re: Pinhole in the oilpan... easy fixes?
[Re: wunderless]
#1084169
09/28/11 09:39 AM
09/28/11 09:39 AM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
JB weld or epoxy for a temporary fix. If you have a hole from rust it will only get worse. Best bet is to change the pan.
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: wunderless]
#1084172
09/28/11 10:38 AM
09/28/11 10:38 AM
Posts: 2,536 o
wunderless
o
Thanks for the answers! Hadn't thought about the epoxy. Should have mentioned it isn't cause by rust, best I can see anyway. Just appears to be a small little hole.
I really thought I had to pull the engine to pull the pan. I would like to get it temporarily corrected that allows me to drive it, till I can afford to yank the engine and go through it. It see's limited use in the summers.
Please keep any more suggestions coming. These are very helpful. They are appreciated!
[Re: bonefish]
#1084174
09/28/11 11:46 AM
09/28/11 11:46 AM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
just use a #6 sheetmetal screw and some rtv,sand the area around the hole then just snug the screw down,its a permenent fix.
haha, that's what i said in my post above; except you got all fancy with a #6 screw and all!!! by far the easiest way to fix it...takes 3 mins...
[Re: ahy]
#1084181
09/28/11 09:16 PM
09/28/11 09:16 PM
Posts: 10,736 North Dakota
6PakBee
North Dakota
Clean it up good and solder it with a big electric gun.
[Re: 69chargeryeehaa]
#1084182
09/29/11 02:11 AM
09/29/11 02:11 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
great minds think alike.
[Re: bonefish]
#1084183
09/29/11 09:00 AM
09/29/11 09:00 AM
Posts: 2,536 o
wunderless
o
Thank you all for the replies!
My first idea was silver solder. I don't have access to a welder either, sadly, or I think I might have tried that.
I might actually give the screw/epoxy thing a go. Sounds pretty easy and safe.
Will be able to get at it next weekend during Thanksgiving (Canadian), which gives me 3 days to screw it up.
You guys rock!
