Pressure plate hot spots #1083387
09/26/11 10:00 PM
09/26/11 10:00 PM
Blair, NE
cudacam Offline OP
cudacam  Offline OP
Blair, NE
My SPEC stage 2 clutch didn't get seated properly and this is the result. Is this pp ok to run with a new disc and re-surfaced flywheel?
Re: Pressure plate hot spots [Re: cudacam] #1083388
09/26/11 10:03 PM
09/26/11 10:03 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
No it needs to be surfaced too.
Re: Pressure plate hot spots [Re: Challenger 1] #1083389
09/26/11 11:40 PM
09/26/11 11:40 PM
Blair, NE
cudacam Offline OP
cudacam  Offline OP
Blair, NE
Should I try to resurface or just get a new plate with the disc? I didn't know how much you could take off the plate and not affect the pressure.
Re: Pressure plate hot spots [Re: cudacam] #1083390
09/27/11 08:00 AM
09/27/11 08:00 AM
Cincinnati, Ohio
Cincinnati, Ohio
Talk to Brewers, they will know. Some pressure plates can be resurfaced with a flywheel grinder.
Re: Pressure plate hot spots [Re: Challenger 1] #1083391
09/27/11 11:09 AM
09/27/11 11:09 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Get a new plate.
logan426
