Finally got on the dyno #1083357
09/26/11 09:44 PM
09/26/11 09:44 PM
Great Neck,LI,new york
hemi-itis Offline OP
It was a long time coming after a few postponments got on the dyno last week with my hemi that was just freshened by Alan from Advanced Race cars{ARC here on the board} out of Patterson.Took me a few days to absorb what happened in the 2 afternoons on the dyno.After mounting the engine and all hoses & wires filled the SV1 carbs with pump gas and a feww squirts and it fired at the hit of the starter.Great start,went to start some pulls and there was an issue with the dyno throttle and my carbs.The 11 inches of vacume under the carbs was too much for the dyno to open.I was noy happy To my surprise,There was this guy loitering at the shop that just happened to have a real nice pair of PRO SYSYTEMS Dominators he would allow me to use He was alreadt kind enough to ley me use his "A" body headers so that the o/2 sensors had a good location.So I must give Steve Gill {steve gillman} here on the bord a HUGE thank you for being in the right place at the right time .I don't usaually have that luck.Bill & Frank are awsome guys from Bill Cerralli Racing and help make my visit very comfortable and enjoying.Frank ran the dyno and made me very happy!!
Check out the Vid>>>> http://www.youtube.com/watch?v=YpXgN2Ul2...&playnext=4
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Finally got on the dyno [Re: hemi-itis] #1083358
09/26/11 10:48 PM
09/26/11 10:48 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
Numbers??
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: Finally got on the dyno [Re: hemi-itis] #1083359
09/26/11 11:08 PM
09/26/11 11:08 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i bet it felt good to make some noise!
Re: Finally got on the dyno [Re: Clanton] #1083360
09/27/11 12:16 AM
09/27/11 12:16 AM
Waited a long time to cross that hurdle.Made some very conservitive pulls starting at 26* timing and pump gas at 4 lbs of boost made 700ish. 28* race gas @8 lbs about 800 HP and 10 lbs made 900.I ran out of pullies for more boost. The word at PRO TORQUE,Joe said 3 weeks to get a converter right now.So hurry up and wait.
Re: Finally got on the dyno [Re: hemi-itis] #1083361
09/27/11 10:18 PM
09/27/11 10:18 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Great going Al. I am glad to see you got it done. Runs better without the 750's you had on there
so how much boost is that thing capable of putting out? Breaking the 1,000 mark should be a no brainer.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Finally got on the dyno [Re: Dap] #1083362
09/28/11 12:15 AM
09/28/11 12:15 AM
1000+ is just a pulley change away.I'll wait 'till after the data logger is installed before going more than 10 lbs It's still a streeter
Re: Finally got on the dyno [Re: hemi-itis] #1083363
09/28/11 07:21 PM
09/28/11 07:21 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Looks killer, what car is it going into?
Re: Finally got on the dyno [Re: 68KillerBee] #1083364
09/29/11 08:08 AM
09/29/11 08:08 AM
Right back where it came from
Re: Finally got on the dyno [Re: hemi-itis] #1083365
09/29/11 06:44 PM
09/29/11 06:44 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
hey AL best of luck,how many lbs if need be,can that blower push w ur engine? and on a side note ur boys belly! looks like he's hideing a helmet under his shirt...lol j/k
Re: Finally got on the dyno [Re: hemi-itis] #1083366
09/29/11 07:00 PM
09/29/11 07:00 PM
Murrieta, CA
BlownHemiCharger Offline
Murrieta, CA
What is the cubic inches? And whos heads did you go with. I am building a 540 blown hemi and was just curious, looking to get around the same numbers!
BlownHemiCharger was here!!
Re: Finally got on the dyno [Re: fishy340] #1083367
09/29/11 08:50 PM
09/29/11 08:50 PM
U r a fny guy JK
Andy,that blower can make over 20 lbs,,,I guess I would LOVE to feel 15 lbs Hope to drive it before the 1st SNOW
Re: Finally got on the dyno [Re: BlownHemiCharger] #1083368
09/29/11 08:56 PM
09/29/11 08:56 PM
545 inch with stockish iron heads
Re: Finally got on the dyno [Re: hemi-itis] #1083369
10/01/11 04:13 PM
10/01/11 04:13 PM
Murrieta, CA
Murrieta, CA
Whats the Static Compression, only 4 Lbs on pump gas!!!
Re: Finally got on the dyno [Re: BlownHemiCharger] #1083370
10/01/11 05:32 PM
10/01/11 05:32 PM
Static is 8:1.With iron heads I didn't want to go more than 10:1 on pump gas.The timing was very conservitive @28*
http://www.blowerdriveservice.com/techcharts.php
Re: Finally got on the dyno [Re: hemi-itis] #1083371
10/01/11 05:44 PM
10/01/11 05:44 PM
2nd pull was 25* of timing with HP of 721@6100
3rd pull was 28* with 739@ 6500 and 646 ft lbs.There is plenty left,just wanted some baseline info.
Re: Finally got on the dyno [Re: hemi-itis] #1083372
10/01/11 06:04 PM
10/01/11 06:04 PM
Murrieta, CA
Murrieta, CA
2nd pull was 25* of timing with HP of [Email]721@6100[/Email]
Ok, I forgot you said Iron heads. I was starting to panic. But I am running fully ported stage V heads. So I will be able to get more boost out of it then 4 LBS.
Re: Finally got on the dyno [Re: BlownHemiCharger] #1083373
11/02/11 02:46 AM
11/02/11 02:46 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
All I can say is.........WOW ! And cool ! Ron
Re: Finally got on the dyno [Re: 383man] #1083374
11/07/11 08:15 PM
11/07/11 08:15 PM
Austin, TX
HemiDave Offline
HemiDave  Offline
Austin, TX
Cool numbers, Al! Always best to keep some in reserve...
Re: Finally got on the dyno [Re: hemi-itis] #1083375
11/07/11 09:08 PM
11/07/11 09:08 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Congrats, nothing more pleasing than hearing your own Hemi sing on the dyno
Going to be a fun ride on the street thats for sure
All the best,
Mark . . .
Re: Finally got on the dyno [Re: mopar_mark] #1083376
11/08/11 10:58 AM
11/08/11 10:58 AM
Thanks Mark,will you still be driving yours in the streets of our motherland??
