FRONT SUSPENSION PAINT DABS
#108301
08/21/08 12:06 PM
08/21/08 12:06 PM
Posts: 1,169 Richmond, VA
rayztoy
Richmond, VA
Hi Guys, How were these markings applied at the factory? Thanks! Ray
Re: FRONT SUSPENSION PAINT DABS
[Re: rayztoy]
#108302
08/21/08 12:12 PM
08/21/08 12:12 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
You need to be more specific with the model, year, and motor of the car you have. Did you carefully steam clean and scrub you existing suspension to find any of the true factory marks you car came with? Look at this thread for examples: https://board.moparts.org/ubbthreads/show...=0&fpart=34
[Re: rayztoy]
#108308
08/22/08 11:34 AM
08/22/08 11:34 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
I was told by an Los Angeles assembly line worker that the paint was applied by a applicator. The applicator was basically a wooden stick with a cotton fabric end on it. Makes senses.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#108312
08/22/08 09:21 PM
08/22/08 09:21 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Good info.
And the colors are just leftover stuff from the paint room right?
Tav
This is what many people believe.
One of the stories is that if the inspection mark was applied at the factory and not by the vendor that was assembling the part.........the factory inspection make could only be a color that was used that model year and also at that plant. For example there was a "lime light" paint dab on my RT front brake caliber. That was a color that was used in Hamtramck in 1970......you would not see a lime light inspection mark in 1968.....that color was not avaliable.
THIS IS ONLY A THOUGHT AND IS NOT GOSPEL.
That was my thinking, but I have seen too many examples that refute that theory.
The black A12 Superbee that I finished this spring had several lime green paint marks on the front end components. And this was a positively original car that had never been disassembled until I took it apart. The only thing I could possibly attribut this to is the fact that the A12's are known to have been built well into the 69 model year and maybe some of this hi impact paint was available in anticipation of the 70 model year.
Here is a pic of the original ball joint-clearly showing the lime green mark.
MB
[Re: HPMike]
#108313
08/23/08 02:24 AM
08/23/08 02:24 AM
Troy
West Coast, CA
Very interesting, nice example.
[Re: Troy]
#108314
08/23/08 03:20 AM
08/23/08 03:20 AM
Posts: 463 IN
polaraholic
IN
I don't know about the suspension but in the late 70's I ran the leadoff machine for the caseline. We used a small refillable plastic bottle with a top that had about a 1" fiber wick to mark which head on the machine the case came off of. The color we used depended on the shift. I was on afternoons and we used green. the other two colors were black and blue. Also it wasn't paint we used it was ink that came in gallon jugs. Steve
