Spark Plug cross with J11Y #108261
08/21/08 10:27 AM
08/21/08 10:27 AM
Port Reading, NJ
roadrunner7070 Offline OP
Port Reading, NJ
I need to replace my Champion J11Y plugs on the 70 Roadrunner 383 Auto. Can't find these or J10Y but I see that the J11Y crosses with new Champion W7FC. Mechanic does not want to go with the J12Y which is a hotter plug. Wants a colder plug. Any suggestions. This is not for racing just cruising. I just need a new set of plugs that will work.
Re: Spark Plug cross with J11Y [Re: roadrunner7070] #108262
08/21/08 12:48 PM
08/21/08 12:48 PM
Port Reading, NJ
Port Reading, NJ
So I guess no one uses spark plugs in their mopars anymore?
Re: Spark Plug cross with J11Y [Re: roadrunner7070] #108263
08/21/08 12:49 PM
08/21/08 12:49 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Autolite 75's I believe. I use Autolite 74's or 73's in the 440 in my 63. Ron
Re: Spark Plug cross with J11Y [Re: 383man] #108264
08/21/08 12:53 PM
08/21/08 12:53 PM
Port Reading, NJ
Port Reading, NJ
Thanks Ron. I had heard of a suggestion of Autolite 85's also.
Re: Spark Plug cross with J11Y [Re: roadrunner7070] #108265
08/21/08 01:04 PM
08/21/08 01:04 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
autolite 85, j12y is o.k. for cruising. i use bosch 4036 in both my 440's; they're a tad hotter than the j11y.
Re: Spark Plug cross with J11Y [Re: lewtot184] #108266
08/23/08 08:44 PM
08/23/08 08:44 PM
Port Reading, NJ
Port Reading, NJ
Thanks for the suggestions. My local auto store dug up 5 boxs of Champion J10Y with 8 plugs to a box. I bought all 5 boxes. 4 boxes will be appearing on ebay shortly.
Re: Spark Plug cross with J11Y [Re: roadrunner7070] #108267
08/23/08 11:59 PM
08/23/08 11:59 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Spark Plug cross with J11Y [Re: 70sixpkrt] #108268
08/24/08 08:22 AM
08/24/08 08:22 AM
BDW Offline
BDW  Offline
That's pretty nice!
Thx
Re: Spark Plug cross with J11Y [Re: roadrunner7070] #108269
08/24/08 11:23 AM
08/24/08 11:23 AM
Interesting....I run rj12yc's in my 383 with orange/silver box and accel/msd coil in my 73 charger with no problems.
You must have a high compresion ratio? I have 150-160 psi cold cranking per cyl.
I heard the autolites where good too.....
Re: Spark Plug cross with J11Y [Re: 70sixpkrt] #108270
08/24/08 01:15 PM
08/24/08 01:15 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
Try this: http://home.att.net/~ngkaz/wsb/Master_Cross_Reference_Charts4.xls
That is cool - worth holding on to...
Anyone else notice "Mighty" is right before Mopar? - coincidence - I think not...
Re: Spark Plug cross with J11Y [Re: roadrunner7070] #108271
08/24/08 01:46 PM
08/24/08 01:46 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Auto-Lite 85s, same as 75s but resistor..
Re: Spark Plug cross with J11Y [Re: 70sixpkrt] #108272
08/24/08 08:24 PM
08/24/08 08:24 PM
Port Reading, NJ
Port Reading, NJ
Program will not open. Appears to be Excel which I don't have.
Re: Spark Plug cross with J11Y [Re: roadrunner7070] #108273
08/24/08 09:28 PM
08/24/08 09:28 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
The J10Y are a colder heat range and were recommended for racing street/strip combo's by Chrysler in their old performance bulletin's. With today's gas, I would stick with a J11Y or equal?
Re: Spark Plug cross with J11Y [Re: RoadRunnerJD] #108274
08/24/08 10:03 PM
08/24/08 10:03 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
New Autolites I hear are made in China. And they have reliability issues. I was using them. I am thinkin NGK or back to Champion.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
