Page 1 of 3 1 2 3
Cam duration vs cubic inches #1082417
09/25/11 08:31 PM
09/25/11 08:31 PM
nc
E
emarine01 Offline OP
E
nc
Ok you guys all know the old saying... cubic inches eats cam duration... so with that being said.... About how much rpm will cubic inches consume with the same cam < Example > 360 cid vs 408... same 12 to 1 compression solid roller with 265@.050... lets assume the heads are up to the task on both engines.... The main reason for the question is that most cam grinders give rpm ranges for stock cid engines... so when you throw more stroke into the equation the rpm is somewhat of a guess
Re: Cam duration vs cubic inches [Re: emarine01] #1082418
09/25/11 09:14 PM
09/25/11 09:14 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Man you ask tough questions....makes my head hurt. But I'll be looking forward to the answers.
Yeah, it's got a smallblock.
Re: Cam duration vs cubic inches [Re: emarine01] #1082419
09/25/11 09:19 PM
09/25/11 09:19 PM
NC
440Jim Offline
440Jim  Offline
NC
Yea, that is a tough question, and I don't have the answer.
But if you change the question to the same heads, intake, headers, cam and only change the CID, you might get some guesses.
I do agree that cubic inches like more duration, but that is based on the same heads/flow. And typically head restricted combos with the extra cubic inches.
You don't need a lot of duration with small CID and good head flow. But you do need the valve train to handle the extra rpm.
Re: Cam duration vs cubic inches [Re: 340B5] #1082420
09/25/11 09:51 PM
09/25/11 09:51 PM
nc
E
E
nc
This is what happens when I get bored So if the 265 solid roller has a power band of say 5000 to 7500 in 340 cid... whats the power band @ 408? & to take it one step further if the cam is 108 in @ 104 in the 340... would it make sense to install it straight up in the 408?
Re: Cam duration vs cubic inches [Re: emarine01] #1082421
09/25/11 10:01 PM
09/25/11 10:01 PM
Guitar Jones Online laugh2
I don't have any answers for you but I'm hoping it isn't much.
I'm basically going from a 363 to a 408 with the same heads but a bigger valve, 20 cfm more flow, a solid roller from a flat tappet but the duration at .050 numbers are within 1 degree of each other but about .030 more lift. Since I can only buy 1 ratio of pro gear for my 8.75 it's much harder for me to change the RPM range I can run the car in. However since most racing down here these days is 1/8 mile it's a lot more forgiving.
Re: Cam duration vs cubic inches [Re: Guitar Jones] #1082422
09/25/11 10:18 PM
09/25/11 10:18 PM
nc
E
E
nc
Maybe 440Jim hit it on the heads The need for more duration for the cubes assumes a restricted head flow on the larger cid combo
Re: Cam duration vs cubic inches [Re: emarine01] #1082423
09/25/11 10:38 PM
09/25/11 10:38 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Ok you got me thinking about it
360/1728 X (RPM/2) = CFM
CFM /(408/1728) = (RPM/2)
The CFM answer from the 1st formula for the 360 is used in the 2nd formula to get the the RPM at which the 408 draws the same air.
Re: Cam duration vs cubic inches [Re: emarine01] #1082424
09/25/11 10:45 PM
09/25/11 10:45 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
The same cam and head with only a cubic inch change will make aprox the same hp. The larger engine will just make it at a lower rpm. For the 408 to to make its power peak at the same rpm as a 360 the camshaft will have to have more duration and heads need a larger port that moves more air.
Getting old just means you were smarter than some and luckier than others.
Re: Cam duration vs cubic inches [Re: dannysbee] #1082425
09/25/11 11:20 PM
09/25/11 11:20 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
1 degree more duration per 10 cubic inches will keep you in the same power band everything else considered. This is just a general rule and hopefully this is correct cuz that's what I remember. So if you add 60 cubes add 6 degrees@050 would be best.
Re: Cam duration vs cubic inches [Re: viperblue72] #1082426
09/25/11 11:29 PM
09/25/11 11:29 PM
nc
E
E
nc
Anyone got a calc that can take a crack @ the math inputting 7500 rpm for the 360? I seem to be too retarded to get any recognizable numbers on my phone calc
Re: Cam duration vs cubic inches [Re: emarine01] #1082427
09/26/11 12:07 AM
09/26/11 12:07 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Aprox 6700 for the 408 with the same heads and cam as the 360 with a 7500 power peak.
Re: Cam duration vs cubic inches [Re: emarine01] #1082428
09/26/11 12:21 AM
09/26/11 12:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Well I cant answer the question YET but I'm running
a 260/262 roller in my 416... I am hoping that it
peaks at 6800 rpm... this is on my W-5 416 I built
for the Rampage... I only want a 7000 rpm engine, max...
this is a throw together parts engine(everything I
had laying around the shop)... I want 550 or so HP
so I should be close
Re: Cam duration vs cubic inches [Re: emarine01] #1082429
09/26/11 12:24 AM
09/26/11 12:24 AM
I don't know the math but I did switch heads, intake and carbs. this year on my pump gas 518 C.I. street motor keeping the same solid roller camshaft similar to yours, 260 @ .050 intake and 266 @ .060 exhaust side. The motor had a set of CNC ported Eddy RPM heads (intakes flowed 310 CFM at .700 lift at 28 inches of water on a Superflow 600 bench)with a six pak intake and carbs, it made peak power at 5800 RPM the last time it was on a engine dyno and peak torque at 4600 RPM. I switch the heads to a set of Indy SR max wedge ports that flowed 350 CFM at .700 lift on the same flow bench as the Eddy RPM, the peak HP is now at 7000 RPM and peak torque was at 4800 RPM The car use to cross the finish line in the 1/4 mile at 6200 RPM with the old heads and intake system and now crosses at 7000 RPM with the Indy 400-3 intake and a single Holley 1050 CFM Dominator, no other changes I say use the cam you got to start with and see if you like the results
Re: Cam duration vs cubic inches [Re: dannysbee] #1082430
09/26/11 12:30 AM
09/26/11 12:30 AM
nc
E
E
nc
Wow, that's 300 more rpm drop than my best guess So If we apply the 1* per 10 cube rule 360 to 408 lets say 5* more duration, about how much will rpm rise?
Re: Cam duration vs cubic inches [Re: emarine01] #1082431
09/26/11 12:39 AM
09/26/11 12:39 AM
I'm a racer and engine assembler, not a engine sceinintest(SP ) or theoryist I can call Comp Cams race dept. tomorrow and get their engineers involved, if you want, That is who I use on new engine combinations for racing, PM me with more info on your total combination
Re: Cam duration vs cubic inches [Re: Cab_Burge] #1082432
09/26/11 12:49 AM
09/26/11 12:49 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
on my 440-6
from the eddy,s rpm to the indy sr,s how much more power did you gain
I have a set of stage six heads and would like to try indy sr,s that are max wedge ported with the indy tunnelram six pack setup im working on
1.39 9.85 - 137 mph
Re: Cam duration vs cubic inches [Re: Cab_Burge] #1082433
09/26/11 12:58 AM
09/26/11 12:58 AM
nc
E
E
nc
Thanks for the offer but I am just trying to apply some hard learned info for some easy answers.... or if there are any rule of thumb type answers that are even close to real world results...Sometimes these threads produce some real good info with the math to back it up sometimes not,But its all part of the learning curve, Thats what makes Moparts so cool... the diversity and knowledge of its members Also I did mention I was bored
Re: Cam duration vs cubic inches [Re: emarine01] #1082434
09/26/11 01:24 AM
09/26/11 01:24 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
We know the 360 has to turn 7500 to produce the peak hp. In 7500 revolutions the 360 ci engine moves 2,700,000 cubic inches of air. The 408 will move the same amount of air in 6618 revolutions. May not be exact but I bet it is close. A friend did this with a truck. He built a new 408 short block and used all the parts off his 360. Truck was about a tenth faster and that was it. He had to lower his shift points.
Re: Cam duration vs cubic inches [Re: dannysbee] #1082435
09/26/11 01:38 AM
09/26/11 01:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
IMO.. this is the way to look at it... its a percentage
of increase(everything in a car is a math formula)
Re: Cam duration vs cubic inches [Re: dannysbee] #1082436
09/26/11 01:42 AM
09/26/11 01:42 AM
nc
E
E
nc
Thanks for running the math, the results make sense , very close to some dyno sheets from builds listed on here, That is a good math formula to keep, Thanks to all.... I gota hit the sack, early day tomorrow
Page 1 of 3 1 2 3
