restriction in fuel bypass
#1082403
09/25/11 08:05 PM
09/25/11 08:05 PM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
is there a easy way to see if you have enuff or to much restriction in the fuel bypass before running doing something bad on the car/motor? got half inch pick up sending unit,1/2 new alum line run up to bg belt drive pump comes out of the pump with -8 and up to a tee carb side goes to a 4 port regulator with 4 -6 lines running to the carbs the return coming off the tee has a poppetin the -6 back to the tank with a bout 1 pound of spring pressure is this enuff pressure to supply gas to the carbs?i know it has to have more of a restriction then the needles have or the fuel will simply all run back to the tank
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: restriction in fuel bypass
[Re: Challenger 1]
#1082405
09/25/11 08:22 PM
09/25/11 08:22 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
^^^^^^^^what he said plus you can set/check it with a leakdown gauge. your poppet should also hold a jet for fine tuning the volume you return to the tank.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#1082406
09/25/11 08:33 PM
09/25/11 08:33 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
i took the poppet apart to make sure no trash in it has spring and a type of seat with like 6 small holes in it
[Re: bigtimeauto]
#1082408
09/25/11 09:15 PM
09/25/11 09:15 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
but im gonna have to swap out to a heavy spring first correct?
[Re: bigtimeauto]
#1082410
09/26/11 12:23 AM
09/26/11 12:23 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
can i tweek the spring i got now or where can i get a 6-7 pound spring?
