Shaker Hood Trim Ring Not Lining Up #1082319
09/25/11 06:31 PM
09/25/11 06:31 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
I have a original shaker hood and trim ring (I think). Problem is the ring doesnt line up at all with the holes in the hood. I am not sure if the ring is from a Cuda or a Challenger. Did these things line up with the studs this bad from the factory or is something wrong here.....
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: faud88] #1082320
09/25/11 06:37 PM
09/25/11 06:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Cuda and Challenger trim rings are different, the center lines in the Cuda ring will be sharp/pointed/peaked, where as the challengers front peak will have a broad flat across the top,....are you sure the ring is an original, are the studs threaded steel, or cast posts?
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: DAYCLONA] #1082321
09/25/11 06:49 PM
09/25/11 06:49 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Here is the trim ring, I am pretty sure its factory. it has threaded studs.
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: faud88] #1082322
09/25/11 06:50 PM
09/25/11 06:50 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Another Shot
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: faud88] #1082323
09/25/11 06:54 PM
09/25/11 06:54 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Those studs sure look long. Do they screw into or are they cast as part of the Shaker ring?
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: faud88] #1082324
09/25/11 06:56 PM
09/25/11 06:56 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
One More
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: faud88] #1082325
09/25/11 06:57 PM
09/25/11 06:57 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
That's a Challenger ring, and a Challenger hood, i can't see the posts too well, but if they are threaded rod cast into the ring, it's a repro ring, the threaded studs on some of the repro rings leave a lot to be desired, an original ring will have posts cast WITH the ring, meaning a 1 pc construction, not embedded, an original "stud" will be somewhat tapered in construction, and cut with a speed nut type fastner, not a machine thread nut
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: faud88] #1082326
09/25/11 06:57 PM
09/25/11 06:57 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
They are cast part of the trim ring.....
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: faud88] #1082327
09/25/11 06:57 PM
09/25/11 06:57 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
That appears to me an original Trim ring, but as noted the studs look too long, if it is original it will have a very small cast in part number on the underside of the rear mating flange surface. If you are certain the hood and trim ring are original start looking for modifications to either the hood flange inset holes, or that possibly one or more of the studs have been replaced and put in a slightly off position, proper placement was highly criticle in getting them to work with the rest of the studs. Even when all was right these hoods/rings did not fit perfectly, there was a bit of slop in the gaps around most originals I've looked at.
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: ScottSmith_Harms] #1082328
09/25/11 07:08 PM
09/25/11 07:08 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
another hopefully larger shot
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: faud88] #1082329
09/25/11 07:43 PM
09/25/11 07:43 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
More Pics Coming, does it look Factory?
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: faud88] #1082330
09/25/11 07:45 PM
09/25/11 07:45 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
More....
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: faud88] #1082331
09/25/11 07:46 PM
09/25/11 07:46 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Hood??
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: faud88] #1082332
09/25/11 07:47 PM
09/25/11 07:47 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Another of the hood.
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: faud88] #1082333
09/25/11 07:58 PM
09/25/11 07:58 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The hood itself seems to be authentic, it has the correct features for a Challenger hood, there is a possibility that someone used one of the kits I used to sell to build that hood, they also had the correct shape and feature (no other kit or hood on the market has them right) but based on the assembly details I can see it's either a masterful installation of the kit or it's the real deal.
Most or all of those studs appear to be replacements on the trim ring, and accordingly are off slightly on the locations. The pics that follow are of a Cuda ring with all of it's original cast in studs, the studs should look the same and are in the same locations on Challenger versions
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: ScottSmith_Harms] #1082334
09/25/11 08:02 PM
09/25/11 08:02 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Scott -Is there a aftermarket trim ring that would line up with my factory holes? I really do not like the idea of modifying the hood to fit the ring.
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: faud88] #1082335
09/25/11 08:10 PM
09/25/11 08:10 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
My money would be on the trim ring studs being in the wrong place, I agree, I wouldn't drill the hood to fit a bad ring. The problem is that your options are somewhat limited, no trim ring on the market will fit or look as nice as the original in terms of it's overall size and shape(although the reproductions I used to sell were pretty close). You could find someone to remove and properly relocate your studs, or try to find a good replacement original ring with good studs.
*Did you find the cast in part# on the rear?
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: ScottSmith_Harms] #1082336
09/25/11 08:19 PM
09/25/11 08:19 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
No, I have nothing like that stamped into the ring. I must have a very old aftermarket replacment. This ring has been around for a while.
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: faud88] #1082337
09/25/11 08:26 PM
09/25/11 08:26 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Thoughts on this ring? Its on Shakerhood.com for $100.00?
Re: Shaker Hood Trim Ring Doesnt Line Up [Re: faud88] #1082338
09/25/11 08:56 PM
09/25/11 08:56 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
As I said before, there are NO reproductions out there as accurate as your original, that one is no exception. The one I used to sell wasn't bad, but it too fell short of an original, however the stud placement was pretty close (best out there as AFAIK) and MIGHT fit an original hood, you can buy them here: www.restorick.com
