Re: Running with out an alternator
[Re: Lawn Monkey]
#1082143
09/25/11 03:07 PM
09/25/11 03:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Running with out an alternator , how do I do it?
I dont understand the question... first I would say WHY... but if your talking wiring or what
[Re: Lawn Monkey]
#1082144
09/25/11 04:02 PM
09/25/11 04:02 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
My advice, don't.
Modern alternators use so little power it's a moot point. In fact with all the electronics and electrical accessories on race cars these days it may actually be quicker with an alternator and probably certainly more consistent due to keeping the voltage steady.
[Re: Cab_Burge]
#1082148
09/26/11 11:47 AM
09/26/11 11:47 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I have been racing for years and never run a alternator. I always have to charge the battery as often between rounds as I can. A Rock 16 volt battery is one of the best I have found to use not running a alt. and its a plus when cranking. And yes now that I run alcohol and never have to cool the engine,I thought why not run a alt. and never have to charge the battery again. But with running a belt drive fuel pump & vacuum pump(dragster) there is no room left for a alt. I would try running a cheap one if I could but if it hurt my ET it would go in the trash can. PS best way to find out if you would be better with-out one is to try it. You can pick up a cheap belt at Advance and if it works all you have to do is pull the alt. off,if its no help you are only out a few $$$. If I can try something for only a few $$$ to speed my car up,I'll spend the few extra $$$ every time.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1082149
09/26/11 12:20 PM
09/26/11 12:20 PM
Posts: 2,864 IN
Irun5snd8th
IN
Two deepcycle batteries in the trunk. I have made 16 passes in a row without charging the batteries. MSD7, pro power coil, electric water pump, electric fuel pump, fan (sometimes)and 12.5 compression for the starter. I am not affraid to double enter and not charge the batteries. 16 passes from a full charge it finally started to miss a tiny amount.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Lawn Monkey]
#1082150
09/26/11 01:30 PM
09/26/11 01:30 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
We ran our car without a alternator for many years..in fact 20 years.Always charging the batteries,or swapping them out after time trials etc.I installed a 55 amp Denso style alternator and it was the best thing I did.No more battery charging and one less thing to do between rounds.I have upgraded to a 100 amp alt from Tuff Stuff.Did the upgrade as I'm planning on street duty in the future.
