needing help with launch #1082116
09/25/11 01:26 PM
09/25/11 01:26 PM
Indiana
65dragnet Offline OP
Indiana
Well another wasted weekend trying to get my car to launch. Was a total embarrassment at Monster Mopar. My car is totally lazy off the starting line. I'm at my wits end with it. I've rep laced Msd ign box ,coil, carb torque convertor,went through tranny, two step box, even tried foot braking it and it still won't launch.I know I have probably not gave enough info with my combo for some people to help but this car has had 1.38 60 fts. and now i have 1.58 at best will not spin the tires other than the burnout. Sat. it ran the best at 1.57 60ft 10.34 @ 129.80. I let off the transbrake button and the car drives out like a throttle stop car and then it kicks butt and runs flawlessly through the 1/4 mile no misses pops or anything. I'm beat! ANY HELP APPRECIATED
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: needing help with launch [Re: 65dragnet] #1082117
09/25/11 02:12 PM
09/25/11 02:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When did it start the slow launch... did you change
something in the engine... what is the stall on the
converter(when you stall it on the trans brake without
a rev chip)... I had a similar issue when I first
built my car... the stall was WAY TO LOW plus the
valve springs were JUNK so it made no power
Re: needing help with launch [Re: 65dragnet] #1082118
09/25/11 02:47 PM
09/25/11 02:47 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Sounds like convertor to me...I spent several $$$ and weeks a few years ago with a problem pretty much like you described. A new convertor fixed the problem. My car felt like it had a vacuum secondary carb,or, a real slow advancing distributor...which it had neither. Felt like I was chained to the tower till about the 60' marker, then would go fine.
If you like drag racing, support your local track.
Re: needing help with launch [Re: 65dragnet] #1082119
09/25/11 03:14 PM
09/25/11 03:14 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Might try retarding the cam a little.
Re: needing help with launch [Re: Challenger 1] #1082120
09/25/11 03:44 PM
09/25/11 03:44 PM
okla.
sam64 Offline
sam64  Offline
okla.
sounds like when i went to denver the first time,made a 10.90 car an 11.40 car real quick.
Re: needing help with launch [Re: MR_P_BODY] #1082121
09/25/11 05:15 PM
09/25/11 05:15 PM
Indiana
Indiana
Mr P; this all came about when I took my 499 out and replaced it with my known good backup engine,(446c.i.)When freshening this engine I decided to install cam straight up. Big mistake , I did remove two step chip and stalled it against the brake , it wouldn't do 3100 rpms. So I assumed I smoked a convertor. Had the convertor cut open and there was nothing wrong with it. Looked like a new one and by the way this convertor usually stalls 5700 on the brake. Going from there I decided the cam needed to be advanced so I put it back at 4* advanced, where it was originally was.This didn't help either and it still wouldn't stall so I borrowed a convertor and went through tranny just to be sure.Now this convertor will stall 5500 on tranny brake and said now we're getting somewhere. Wrong again! By the way new valve springs too thanks for your input
Re: needing help with launch [Re: Challenger 1] #1082122
09/25/11 06:18 PM
09/25/11 06:18 PM
Indiana
Indiana
Challenger I ,thanks for your reply .I called Comp Cams and ask the Tech people if I should advance the cam timing as to kill a little top end and they agreed I might be in a torque curve problem being this is a pretty big cam for such a small engine. By the way it is290 dur @050 and 650lift , engine is 440 030 over 13.4 cr Indy EZ-1 single plane 950 cfm Quickfuel.
Re: needing help with launch [Re: 65dragnet] #1082123
09/25/11 06:28 PM
09/25/11 06:28 PM
Indiana
Indiana
Going to try another MSD distributor next !
Re: needing help with launch [Re: 65dragnet] #1082124
09/25/11 07:23 PM
09/25/11 07:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you done a compression check... it sounds like
a engine issue not making any torque
Re: needing help with launch [Re: MR_P_BODY] #1082125
09/25/11 08:53 PM
09/25/11 08:53 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
No help here but thought I'd add some humor... When I first saw your thread title I thought it said "needing help with lunch" & I figured Hey I'm there....
Re: needing help with launch [Re: MR_P_BODY] #1082126
09/25/11 08:54 PM
09/25/11 08:54 PM
Indiana
Indiana
No but I will ! I don't think that's an issue but I can't leave a stone unturned. Thanks Mike ! Engine has fresh stress hone new rings and bearings on freshen up, has 20 passes on it now.
Re: needing help with launch [Re: 65dragnet] #1082127
09/25/11 08:56 PM
09/25/11 08:56 PM
Indiana
Indiana
Dang sure don't need help with lunch as fat as I am LOL
Re: needing help with launch [Re: 65dragnet] #1082128
09/25/11 10:23 PM
09/25/11 10:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats the LSA and what do you have it in at.... and
ARE YOU SURE its at that installed degree... its acting
like its down (alot) on torque... you could have broke
some rings on the install (just a guess) but the
compression test should tell you something..... JMO
Re: needing help with launch [Re: MR_P_BODY] #1082129
09/25/11 10:59 PM
09/25/11 10:59 PM
Indiana
Indiana
108 degreed @ 104 checked it twice . Probably will do a leak down on it this week
Re: needing help with launch [Re: 65dragnet] #1082130
10/06/11 01:08 AM
10/06/11 01:08 AM
Indiana
Indiana
Many days have past since my original post and I have finally stumbled onto the problem. I don't have an explaination as to why but , I changed out the transbrake for another , and bingo the launch is back and actually faster. Thanks for the guys who posted and tried to help, I was ready to throw in the towel ! We tested tonight and the car had a best of 10.27 @ 130.71
Re: needing help with launch [Re: 65dragnet] #1082131
10/06/11 01:19 AM
10/06/11 01:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats strange... wonder if it was totally releasing...
did you open up the valve body yet to see whats happening
Re: needing help with launch [Re: MR_P_BODY] #1082132
10/06/11 05:05 AM
10/06/11 05:05 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
i was going to guess dist. advance.. but a new valve body cured it ?
what was the problem with the 1st VB . or have you sent it back ?
Re: needing help with launch [Re: 493_DART] #1082133
10/06/11 08:29 AM
10/06/11 08:29 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
This problem could have been caused by pressure bypass or leakage in the valve body causing a delay in the release or apply of band and clutch timing.
We had a similar problem and found a passage broke through on the plate,we used epoxy to patch the area and it work great.
Re: needing help with launch [Re: B G Racing] #1082134
10/06/11 10:16 PM
10/06/11 10:16 PM
Indiana
Indiana
Thanks guys for the replies , I haven't opened it up yet to have a look see. If I find anything I will post, been fighting this no launch problem for a month now. Sure is good to get somewhere finally , a real pita !
