Welding in Cage #1081950
09/25/11 02:43 AM
09/25/11 02:43 AM
Adrian, Mi
P
pro6pakRR Offline OP
mopar addict
mopar addict
P
Adrian, Mi
Plan on putting a CM cage in my 68 Barracuda.What I would like to know is can you weld that cage to stock sheet metal? And how about frame connector? Thanks
Chief Wiseman
Wiseman Racing
Re: Welding in Cage [Re: pro6pakRR] #1081951
09/25/11 04:08 AM
09/25/11 04:08 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
holesaw the floor so you can drop the cage down thru the floor so you can get at your welds then you slide 6x6 plates between the floor and tubes. you can also put in outriggers to attach to bars
Re: Welding in Cage [Re: sixpackgut] #1081952
09/25/11 04:13 AM
09/25/11 04:13 AM
Adrian, Mi
P
mopar addict
mopar addict
P
Adrian, Mi
That part I know .Was wondering if you can weld Cm to MS or the stock sheet metal
Re: Welding in Cage [Re: pro6pakRR] #1081953
09/25/11 04:16 AM
09/25/11 04:16 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
sure. has to be tigged though
Re: Welding in Cage [Re: pro6pakRR] #1081954
09/25/11 08:17 AM
09/25/11 08:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes you can weld CM to mild... at that point it has to
be tigged just like its CM... you use the same rod
Re: Welding in Cage [Re: MR_P_BODY] #1081955
09/25/11 10:17 AM
09/25/11 10:17 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Yes...but is it legal with NHRA?
Re: Welding in Cage [Re: racerx] #1081956
09/25/11 10:28 AM
09/25/11 10:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
That I cant say for FACT but I cant see why not IF
the mild meets the spec and so does the CM... people
add to their roll bars all the time
Re: Welding in Cage [Re: MR_P_BODY] #1081957
09/25/11 10:38 AM
09/25/11 10:38 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Thax. Mr.P Body I've always wonder that as I'm planing adding to my cage and thought about adding cm to the ms to hopefully save a little weight in the process.......
Re: Welding in Cage [Re: MR_P_BODY] #1081958
09/25/11 10:56 AM
09/25/11 10:56 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
It is perfectly legal with SFI to weld chrome moly to mild steel. But, all the tubing involved has to meet the SFI spec.
My question is why would you weld chrome moly to the original sheetmetal?
As far as the basic cage there are requirements of what it welds to. Box tubing must be .083" thick. Round tubing also has to be .083 for chrome moly and .118 for mild steel. Your stock unibody frame rails are not .083" in all places. When they are that thick it is usually due to layers of sheet metal. You would need to penetrate the layers. If you are welding to the floor, use a 6"X6" plate. The rear frame rails for the rear support bars can be done several ways. The best is probably a 6"X6" bent to wrap the rear frame rail. Brake the corners down to make a diamond formation. This will provide the strongest support without compromising the strength of the frame rail. The front frame rails are thick on top but layered. If you choose to weld on top of the frame it is tricky to penetrate the frame rail without burning the tubing up. I have seen several approaches.
If you want your cup on your tig torch to live welding on Mopars? You better leave the tig alone when welding to the stock sheetmetal. I choose to mig a plate to the stock metal. Then tig my chrome moly to the plate. I have seen extremely weight conscious people weld a heavy bead with a mig, grind it flat, then tig the tubing to it. I feel that is a wast of time. I don't know why but my tig hates stock mopar sheetmetal. I have tried everything from 64-97 and got the same results. Chevies and Fords seem to do just fine.
I just got through welding a roof skin on a Dakota that the guy drilled all the way through on the spot welds at the rear door corner. This was a criticle area as the headliner is in the truck. So I had to tig it to not catch everything on fire. When I got done I had to rebuild the torch head. Just another $20 on the bill. LOL
Leon
Re: Welding in Cage [Re: Leon441] #1081959
09/25/11 12:15 PM
09/25/11 12:15 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
The first time I tried to certify my car it was turned down because I had some CM bars in the MS cage. The guy that built the cage did it and I don't know why. I had to change those bars to MS and he certified it the next try.
Re: Welding in Cage [Re: Blucuda413] #1081960
09/25/11 01:32 PM
09/25/11 01:32 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
the reason it would have got turned down is because he didnt know if it was really CM or thin tube MS i would think. was it all tigged or migged?
Re: Welding in Cage [Re: Blucuda413] #1081961
09/25/11 02:23 PM
09/25/11 02:23 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Was probably MIG welded.. Can't MIG weld CM.. If it was tigged and was proper thickness no reason for them to reject it..
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Welding in Cage [Re: DemonDust] #1081962
09/25/11 10:38 PM
09/25/11 10:38 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Bluecuda413 was it a combination of tig/mig or what? I'm curious as i'm going to add some more bars (cm)and tig them in,but the ms bars r mig............Thax.
Re: Welding in Cage [Re: racerx] #1081963
09/25/11 10:53 PM
09/25/11 10:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was waiting to get my car certed and the inspector
would ask what bars were what dia and thickness
before he even started the inspection... if the person
didnt know he would ask if you wanted him to continue
and if he started the inspection it cost the inspection
price weather it passed or not... if you didnt know
the specs(for the cert you were going for) and he measured
the bars at a different thickness or dia you could fail...
dont know why if the stuff is in spec
Re: Welding in Cage [Re: racerx] #1081964
09/25/11 11:37 PM
09/25/11 11:37 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
The inspector could probably tell it was CM by the thickness. All he mentioned and entered on the form was the CM tubes. He mentioned nothing about the welds. I assume it was probably migged but I don't really know. These 2 bars were the main hoop brace bars. Anyway replaced those with MS and passed OK.
Re: Welding in Cage [Re: Blucuda413] #1081965
09/26/11 02:28 AM
09/26/11 02:28 AM
Adrian, Mi
P
mopar addict
mopar addict
P
Adrian, Mi
When I use to help Pinkie cert cages,when I worked at Milan,he had an thing he called a pinger that made a different sound on CM.
