plug fouling #1081745
09/24/11 09:22 PM
09/24/11 09:22 PM
Home of the Bluegrass
MoparJunkie Offline OP
Hey guys I have a 505" six pack motor... took it on a long run today... 120 miles, and now cyl's 1 & 4 have rich fouled plugs(black soot). All the other cyl's plugs are tannish brown color... What gives??? How can just those two plugs foul like that?
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: plug fouling [Re: MoparJunkie] #1081746
09/24/11 09:36 PM
09/24/11 09:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
3 things come to mind... too cold of plugs... too fat
on the fuel and a poorly flowing intake(the runners
arent balanced)
Re: plug fouling [Re: MR_P_BODY] #1081747
09/24/11 09:41 PM
09/24/11 09:41 PM
If I was too fat on the fuel wouldn't I have more than 2 fouled plugs????? I can understand the runner issue??? I am running a NGK BKR6E plug...
Re: plug fouling [Re: MoparJunkie] #1081748
09/24/11 10:08 PM
09/24/11 10:08 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i'd do a leak down test on those clyinders. check ur valve adjustment also. stay safe, seeya.
Re: plug fouling [Re: MoparJunkie] #1081749
09/24/11 10:10 PM
09/24/11 10:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Since all of them are a tad fat(tan color) you could
jet down or put in a hotter plug... or put in a hotter
plug in those 2 cyl(it will work but not my first
choice)
Re: plug fouling [Re: MoparJunkie] #1081750
09/24/11 10:42 PM
09/24/11 10:42 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i dont know if you have stock carbs or metering plates that take jets, but from the factory the carbs are stagger jetted. you have a deep plenum and a short plenum. not sure on this but one plenum feeds 1467 and the other 2358. i jetted my carbs till they all looked the same.
besides, i still dont think that is the issue
Re: plug fouling [Re: MoparJunkie] #1081751
09/24/11 10:53 PM
09/24/11 10:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you checked your plug wires lately... you could
have a couple going bad
