How can I convert my amp gauge in to a volt gage
#1081732
09/24/11 08:14 PM
09/24/11 08:14 PM
Posts: 26 colorado
929lamasters
colorado
I have a 70 R/T Challenger and I want to know how can I keep the factory amp gauge but use it as a volt gauge is this possible or am I thinking unrealistic. Also I would like to do it my self so instructions and parts needed would be nice thank you
Re: How can I convert my amp gauge in to a volt gage
[Re: 929lamasters]
#1081733
09/24/11 08:55 PM
09/24/11 08:55 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
There was an article in Mopar Action magazine about doing that and I think the various gauge restoration vendors can also do the work.
[Re: 929lamasters]
#1081734
09/24/11 09:14 PM
09/24/11 09:14 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Don't bother, and don't ruin a good car.
When the battery went bad in my '98 truck, the volt gauge didn't show anything out of the ordinary.
An amp gauge would have shown if it was taking too much of a charge, a charge all the time, or even too little of a charge. Would have told me that the battery was going bad.
A volt meter on the battery itself showed nothing wrong, only a load test showed a bad battery, that and it stalling at stop signs, and a couple people here on Moparts said it could be the battery or a clogged sensor thing behind the throttle body.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: 929lamasters]
#1081737
09/24/11 10:53 PM
09/24/11 10:53 PM
Posts: 5,447 So Cal
Sinitro
So Cal
A good electrical shop such as Red Line gauges can take a fuel or oil pressure gauge change the front face, insert a shunt resistor and convert to a volt meter. Then it can bolt into the ralley dash and connect it across 12 volts. It is actually straight forward but because most guys are uncomfortable about wiring, its best to use an experienced electrical shop.
Just my $0.02..
