843 g. vs. 701 g. #1081161
09/23/11 08:41 PM
09/23/11 08:41 PM
California
mickm Offline OP
mickm  Offline OP
California
i weighed a stock hemi piston - 843 grams.
new pistons going into the 540 - 701 grams.
that should take a load off of the reciprocating weight!
Re: 843 g. vs. 701 g. [Re: mickm] #1081162
09/24/11 12:06 PM
09/24/11 12:06 PM
gregsdart Offline
gregsdart  Offline
Sure will help! that is 2.5 lbs for pistons alone. Then add the weight taken out of the crank and that is a lot less metal swinging around.
