Removing a ignition tumbler in a 73 dodge dart #1080955
09/23/11 03:33 PM
09/23/11 03:33 PM
Colorado Springs,Colorado
Roadrunner440-6 Offline OP
can anyone tell me how to remove the old ignition key cylinder. This is in the steering column..Any help will be greatly appreciated Thanks.
Re: Removing a ignition tumbler in a 73 dodge dart [Re: Roadrunner440-6] #1080956
09/23/11 04:47 PM
09/23/11 04:47 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Remove the steering wheel and disassemble the column. Bag and tag everything. IIRC the ignition tumbler is held in with one screw.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
