Pin caliper installation fight #1080947
09/23/11 03:16 PM
09/23/11 03:16 PM
MN
astrobuf Offline OP
astrobuf  Offline OP
MN
Ok, after fighting for two days now, trying to get my Challenger's pin calipers back on the car, I must be doing something wrong. New calipers, pads, rotors and pins. Try as I might, I cannot get both caliper pins to thread up. There must be a trick to doing this?
This is the first time I've had these off and if it's always this hard, may be the last time I do this ;0
Is it supposed to be this hard? What's the trick way to do this?
Astrobuf
So, are you really a Rocket Scientist?
Re: Pin caliper installation fight [Re: astrobuf] #1080948
09/23/11 04:49 PM
09/23/11 04:49 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Are the pins straight?
Re: Pin caliper installation fight [Re: DAYCLONA] #1080949
09/23/11 04:54 PM
09/23/11 04:54 PM
MN
astrobuf Offline OP
astrobuf  Offline OP
MN
Pins, calipers, bushings, pads and rotors are all new. Wagner and Raybestos parts, so the quality is good. Chased all the threads male and female?
Astrobuf
Re: Pin caliper installation fight [Re: astrobuf] #1080950
09/23/11 05:11 PM
09/23/11 05:11 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
There's a member on this forum that knows lot's about this subject.
But i don't any longer know who it is.
It appears that there is a difference in calipers where the holes are drilled on the "ears" of the mounting points of the calipers.
But that's about all that i remember about the subject.
I saved a photo from one of his replies.
Dunno if this might be your problem though, with you saying that you have replacement calipers.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Pin caliper installation fight [Re: hemi71x] #1080951
09/23/11 05:43 PM
09/23/11 05:43 PM
MN
astrobuf Offline OP
astrobuf  Offline OP
MN
Hmm, I wonder if this is part of the solution. I'm rebuilding my '71 Challenger which appears to have '73 spindles and calipers on it. Truth is, I'm not sure what year each part if from, beyond the spindles which I know to be '73's based upon the large bearing journals. The dust shield is the corrugated type and so also a '73 I think. the caliper support casting, not sure.
Astrobuf
Re: Pin caliper installation fight [Re: astrobuf] #1080952
09/25/11 06:49 PM
09/25/11 06:49 PM
MN
astrobuf Offline OP
astrobuf  Offline OP
MN
Bump
Astrobuf
Re: Pin caliper installation fight [Re: astrobuf] #1080953
09/26/11 12:37 AM
09/26/11 12:37 AM
MN
astrobuf Offline OP
astrobuf  Offline OP
MN
OK, took the pads out of the install. The caliper and pins fit and thread up fine. Something about the new pads is interfering with the install.
Astrobuf
Re: Pin caliper installation fight [Re: astrobuf] #1080954
09/26/11 11:05 PM
09/26/11 11:05 PM
MN
astrobuf Offline OP
astrobuf  Offline OP
MN
Hemi71x - You pointed me in the right direction. I mic'd the old caliper and the new caliper large bushing bore to the milled ear dimension. The NAPA premium rebuilt caliper was about 0.015 thicker. This caused an interference when I tried to get the two pin bolts in.
I put new bushings in the old calipers and they mounted right up!
Now I've got to get NAPA to order the replacement calipers in, there are none in the state! Wasted a week on this, but at least it's figured out.
Anyone know where to find the other caliper detail poster that Hemi71x referenced?
Astrobuf
