Page 5 of 5 1 2 3 4 5
Re: Having issues with my EZ EFI (still) [Re: Slipknot440] #1080230
10/17/11 12:16 AM
10/17/11 12:16 AM
Oklahoma
Rodeok69 Offline
Rodeok69  Offline
Oklahoma
I was having the same problems and I got em fixed. My setup is a lot different, but the issues are identical. Your numbers for the IAC are critical. At 800 rpm, your IAC is showing 180, or fully open. So what it's doing is pulling tons of air at idle, which is skewing the AFR to show lean and consequently dumping fuel to compensate and fouling your plugs. It should read around 10 at idle. It is so critical to set your TPS correctly as well as the idle screw for your throttle blades. It will eliminate the majority of what you have going on at idle. Changing fuel pressure will do little or nothing for you. Leave it at 43psi. Don't give up on it. I almost did until I got it right. Now I like it.
Cody
Re: Having issues with my EZ EFI (still) [Re: Rodeok69] #1080231
10/18/11 05:39 PM
10/18/11 05:39 PM
Dalton, MA
Slipknot440 Offline OP
Dalton, MA
got it out today. It's the most fun i've had in a car that doesn't involve sex. I hit 130 in no time at about 85% throttle. I'm going to swap out the plugs for a fresh set this weekend. Unfortunately, I've got a small gas leak somewhere around the tank, if it's not one thing it's another. But at least i've got it running just good enough to have to put it away for the winter
Re: Having issues with my EZ EFI (still) [Re: Slipknot440] #1080232
10/18/11 07:54 PM
10/18/11 07:54 PM
Oklahoma
Rodeok69 Offline
Rodeok69  Offline
Oklahoma
Glad to hear you got it under control!
