What timing light do you like? #1080094
09/21/11 11:22 PM
09/21/11 11:22 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
I need to get a timing light for personal use. Any recomendations?
Re: What timing light do you like? [Re: lahatte] #1080095
09/21/11 11:37 PM
09/21/11 11:37 PM
IN
ahy Offline
ahy  Offline
IN
I have two. A Sears "dial back" and a Flaming River battery powered unit. The MSD ignition on my hot rod drives the Sears nuts. It jumps all over. No problem with the Flaming River and MSD. I like the MSD... and keep the Sears in reserve for non-MSD vehicles without degreed dampers or timing tape.
Re: What timing light do you like? [Re: ahy] #1080096
09/22/11 09:00 AM
09/22/11 09:00 AM
Central TX
roe Offline
roe  Offline
Central TX
I got a cheapie from Autozone, dont even remember the brand. But I'm only working on my car, a daily driver, so I can get away with it.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: What timing light do you like? [Re: roe] #1080097
09/22/11 09:51 AM
09/22/11 09:51 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Both me and my friend Tony have Sears dial back lights. We set timimg by toal and at 2500 the Sears works fine. I recommed that anyone with a performance motoer set by total timing. It's the only way to be sure of timing.
Re: What timing light do you like? [Re: lahatte] #1080098
09/22/11 10:10 AM
09/22/11 10:10 AM
Way back either Jacobs ignition or MSD I forget which did a test on regular (non dialback) lights & found that the Sears one (I forget the # but it was there std Penske model iirc) was the most accurate (probably was not MSD that did the test as they did not vote themselves #1). IMO I think dialbacks are a slight bit inaccurate (1/2-1 degree) but they are SO much fun to play with! To answer your Q I'd get a good deal on a name brand one on craigslist or eBay and for sure find exact TDC & what works for me is to do the math & use a micrometer to measure a strip of paper & use it as a ruler to make a dead on accurate new slit on the dampener with a hacksaw blade for initial/total (the main ones you need) then use the dailback to check the slope if needed. .0632683" is (1) degree and for example 2&1/4" is 35.5 degrees total
Re: What timing light do you like? [Re: lahatte] #1080099
09/22/11 10:30 AM
09/22/11 10:30 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The blue one in this picture is the best by far out all the timing lights I've tried over the years. It's bright and accurate and I use it with MSD mags. It makes the Flaming River one looks like a peice of junk. Now the Flaming River one is OK, not junk but nothing like the blue one. Mine say French Grimes on it but he don't make it.
Now everyone needs a dial back one also and Sears have always worked good for me. I don't like how the Sears one has a plug in wire, it sucks.
If you don't use MSD the Sears dial back would be my choice.
Re: What timing light do you like? [Re: Challenger 1] #1080100
09/22/11 10:43 AM
09/22/11 10:43 AM
MD
floyd Online content
floyd  Online Content
MD
I bought one of these off Amazon last month. I needed one quick and it had decent reviews. It worked fine.
http://www.actron.com/product_detail.php?pid=16314
Re: What timing light do you like? [Re: lahatte] #1080101
09/22/11 11:04 AM
09/22/11 11:04 AM
Cincinnati, Ohio
Cincinnati, Ohio
This one sold by MSD is just like my blue one, MSD does not make it, but like I said. It's the best one, not the cheapest but the best.
web page
Re: What timing light do you like? [Re: lahatte] #1080102
09/22/11 11:40 AM
09/22/11 11:40 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I still got an old mac red plastic job, and I have the trigger wire tied so that it's flashing as soon as you hook it up. It's cheap, but it does the job.
Re: What timing light do you like? [Re: RapidRobert] #1080103
09/22/11 11:45 AM
09/22/11 11:45 AM
Alberta
rustbuckett68 Online content
rustbuckett68  Online Content
Alberta
Is it a good idea to cut a slot in a balancer with a hacksaw? Wouldn't that cause a stress riser at 6000 RPM?
Re: What timing light do you like? [Re: rustbuckett68] #1080104
09/22/11 11:55 AM
09/22/11 11:55 AM
Cincinnati, Ohio
Cincinnati, Ohio
Paint marker would be a much better idea.
Re: What timing light do you like? [Re: RapidRobert] #1080105
09/22/11 02:14 PM
09/22/11 02:14 PM
Mississippi
lahatte Offline OP
lahatte  Offline OP
Mississippi
To be picky, it's a 'damper', not a "dampener". It doesn't make something wet.
Sorry, a pet peeve.
Re: What timing light do you like? [Re: Challenger 1] #1080106
09/22/11 03:13 PM
09/22/11 03:13 PM
NY usa
540challenger Offline
NY usa
They also sell timing tape too.
Re: What timing light do you like? [Re: 540challenger] #1080107
09/22/11 03:23 PM
09/22/11 03:23 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I use a 1970s Sears, we bought it for my dad when I was younger. It's worked great on anything I've used it on. I've never had a dial back though, always used a degreed balancer or timing tape on one.
Re: What timing light do you like? [Re: justinp61] #1080108
09/22/11 03:54 PM
09/22/11 03:54 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
my equinox is digital, has dial back and displays rpm.
very nice to use
Re: What timing light do you like? [Re: justinp61] #1080109
09/22/11 07:17 PM
09/22/11 07:17 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Same here. No problem with my MSD.
Maybe the dial backs are better today, but I know several guys that had faulty dial-backs that caused them problems for quite a while before figuring it out.
Re: What timing light do you like? [Re: BSB67] #1080110
09/22/11 07:21 PM
09/22/11 07:21 PM
USA
ramairthree Offline
ramairthree  Offline
USA
I have a basic non-dial back cheapie from autozone.
I use a paint marker on the damper slot and the factory markings, at least on my two project drivers.
On my nicer driver I have the timing tape.
Re: What timing light do you like? [Re: Challenger 1] #1080111
09/22/11 08:07 PM
09/22/11 08:07 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
The blue timing light in your pic is made in USA by Ferret Instruments and by far is one of the best timing lights made.
Re: What timing light do you like? [Re: WheelsUp73] #1080112
09/22/11 08:29 PM
09/22/11 08:29 PM
Cincinnati, Ohio
Cincinnati, Ohio
When the brightest minds in racing are using one, you pay attention.
Re: What timing light do you like? [Re: lahatte] #1080113
09/23/11 11:05 AM
09/23/11 11:05 AM
And here I was expecting a "thanks guys for the suggestions" . As mentioned yes a thin straight mark with a permanent paint pen would be better than hacksawing a new slit(s) and the light with the built in tach are real handy especially when a person gets serious about dialing in their curve
