Engine build question #1079741
09/21/11 11:10 AM
09/21/11 11:10 AM
Finally a HUSKER again
Moparnut426 Offline OP
If you popped your engine and basically everything under the heads was junk, how many of you guys could just build another short block without thinking, planning or bugeting the build. There is no way I could, It would take me a few years more than likely to be able to afford another "nice" piece.
Kasey
Re: Engine build question [Re: Moparnut426] #1079742
09/21/11 02:15 PM
09/21/11 02:15 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Hey Kasey, I know what you mean there! If you remember my post "512 Stroker, ZERO power"....still collecting parts and spending $$$$$...I found that either machine shop over-look or my mistake building the engine, ate the cam bearings. Found out cam tunnel off by .003". Might be able to fix, but by the time I spent the cash to fix the block, might as well get another. AND, new bearings...rings...clean...hone...etc...ads up quickly! Jeff
Re: Engine build question [Re: 1969RR] #1079743
09/21/11 02:23 PM
09/21/11 02:23 PM
Yep, I was thinking about it the other day when I found my carb came loose from the main body to the base plate. I thought, man if I would have leaned out, butned up the pistons, or ate a carb screw, theres NO way I would be able to enjoy the car again for quite a while.
I have too many irons in the fire already.
Kasey
Re: Engine build question [Re: Moparnut426] #1079744
09/21/11 02:38 PM
09/21/11 02:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The engine I'm building for my Rampage is just stuff
I have laying around the shop... I had everything except
lower compression pistons... I have most of the big
stuff to build another also... but that would have to
be a W-2 engine... the one going into the Rampage is a W-5
Re: Engine build question [Re: MR_P_BODY] #1079745
09/21/11 02:51 PM
09/21/11 02:51 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I would be right back onn it with another short block in a matter of days. My wife wouldnt let me quit. Not with how much she knows I love this crap.
Re: Engine build question [Re: POS Dakota] #1079746
09/21/11 03:03 PM
09/21/11 03:03 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Three words.. back up engine .
Without that, I'd be done for a good while.
I shouldn't say that,, I'd find some piece of junk to cam up and put heads on.
Re: Engine build question [Re: RemCharger] #1079747
09/21/11 03:26 PM
09/21/11 03:26 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I was in this situation last year.
After the second motor blew, I had no way of recovering from that. If it had not been for this board and the generosity of it's members as well as my sponsors my car would have been siting a very long time.
Re: Engine build question [Re: WILD BILL] #1079748
09/21/11 03:59 PM
09/21/11 03:59 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I have the stock "#'s" 383 sitting in the corner of my garage. I'd probably be forced to go that route while I built another bullet, which would take me a year or so to get the "spare cash" through the wife's approval. It took me about 18 month.s to build my 452, and its a low budget effort by this boards standards.
Re: Engine build question [Re: RemCharger] #1079749
09/21/11 04:07 PM
09/21/11 04:07 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Three words.. back up engine.
I kept my 340 short block as a back up for the 408.
Re: Engine build question [Re: WILD BILL] #1079750
09/21/11 04:19 PM
09/21/11 04:19 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
haha yeah. I couldnt believe it when I read the second blowup thread.
I figured you were about done...especially with all the other stuff you have going on...
Re: Engine build question [Re: POS Dakota] #1079751
09/21/11 07:06 PM
09/21/11 07:06 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I spent more on the 493 eng then I ever have as I actually bought new good parts for this eng and no way could I afford to build another right now even with me building it myself. I do still have my old mid 11 second 440 sitting in my garage even though I sold it to my buddy. Well if its still sitting there in my garage and I would ever need another eng.... ...... . Ah I just hope this one stays together as long as all my budget engines have as actually none of them have ever broke on me. Ron
Re: Engine build question [Re: Moparnut426] #1079752
09/22/11 03:19 AM
09/22/11 03:19 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Took me 5-years to get the new 500" stroker together after the old 451 dropped a valve. Alot of planning and saving for parts, and some changes along the way, along with the usual "unexpected" issues needing more research, parts and $$$$.
Re: Engine build question [Re: 451Mopar] #1079753
09/22/11 04:58 AM
09/22/11 04:58 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
Luckily, I have 3 spare engine's and 3 spare short blocks.But i've been collecting them for 22 years.
Re: Engine build question [Re: pro6pakRR] #1079754
09/22/11 07:08 AM
09/22/11 07:08 AM
Guitar Jones Online laugh2
Well I still have my old 360 SB I could screw together pretty cheaply. In fact with all the hassle I've had with this new stroker I was thinking of doing just that. But it's all coming together now.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
