Operating a RMVB on the street #1079680
09/21/11 08:48 AM
09/21/11 08:48 AM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
My new Trans will have an RMVB (Thanks CRT)
I've never run a RMVB before, and I'd like a heads up on operating it in traffic situations.
Q1 - If I'm waiting at the lights and go to drive off normally - will it hurt the trans if I leave it in D(3rd gear?)
Q2 - If thats not advisable.....- is it OK to take off in 2nd gear?
Car weighs 3650 with me in it and runs a 392 stroker with a 3.91 gear set.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Operating a RMVB on the street [Re: Moparmal] #1079681
09/21/11 08:52 AM
09/21/11 08:52 AM
Guitar Jones Offline
The answer to both questions is why would you. Having said that though it won't hurt the trans but it will build excessive heat and that could hurt the trans and shorten the life of the fluid.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Operating a RMVB on the street [Re: Moparmal] #1079682
09/21/11 08:58 AM
09/21/11 08:58 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Q1 ...I have done that all-the-time ... but ONLY uNder very lite throttle.
Q2 ... Q1 is fine ...so #2 is cool too !
Re: Operating a RMVB on the street [Re: Moparmal] #1079683
09/21/11 10:08 AM
09/21/11 10:08 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Based on your questions, why did you go with a RMVB in the first place? Drive it like you would a manual three speed trans, 1st, 2nd. 3rd.
Re: Operating a RMVB on the street [Re: Dabee] #1079684
09/21/11 12:03 PM
09/21/11 12:03 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
A RVMB is pretty much like a Stick without a clutch pedal. No big deal to drive around, but your downshift speeds should be lowered from what you'd do with a stick, since an AT doesn't match RPMs like a throttle-blip does with a stick.
Re: Operating a RMVB on the street [Re: Moparmal] #1079685
09/21/11 12:19 PM
09/21/11 12:19 PM
Don't do it, start off in 1st every time That way you won't do it(forget to start in 1st gear) at the track either
Re: Operating a RMVB on the street [Re: Moparmal] #1079686
09/21/11 12:39 PM
09/21/11 12:39 PM
organ
maximum entropy Offline
organ
i have a crt rmvb lba (lol) in my heap, and i start in whatever gear i damn well please! usually 2nd in town, sometimes third. no problems with trans temp. pretty loose convertor (4400 flash). do what you want when you want. that is a great valve body, btw. i love mine.
Re: Operating a RMVB on the street [Re: Dabee] #1079687
09/21/11 12:43 PM
09/21/11 12:43 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... Drive it like you would a manual three speed trans, 1st, 2nd. 3rd.
Yep, and I always put it in neutral when sitting at traffic light.
Re: Operating a RMVB on the street [Re: BradH] #1079688
09/21/11 02:32 PM
09/21/11 02:32 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You do need to know if has low band apply. If it doesn't then you dont want to go back in first until you are at a complete stop. Ron
Re: Operating a RMVB on the street [Re: 383man] #1079689
09/21/11 04:35 PM
09/21/11 04:35 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
And low band apply is when the trans does NOT free-wheel in low gear, right??
Re: Operating a RMVB on the street [Re: cudadoug] #1079690
09/21/11 04:42 PM
09/21/11 04:42 PM
organ
organ
i downshift mine into first no problem. going real slow. maybe crt could chime in on this?
Re: Operating a RMVB on the street [Re: maximum entropy] #1079691
09/21/11 06:35 PM
09/21/11 06:35 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Mal,
you wanted the best shift,you got a manual VB.drive it like a manual.
harden up princess
Tex
PS : it won't make you faster just more consistant
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Operating a RMVB on the street [Re: cudadoug] #1079692
09/21/11 06:57 PM
09/21/11 06:57 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yes it will have eng braking in low gear. Without the low band apply it will freewheel in low and you dont want to go back into first at say 10 mph and then hammer it while it is freewheeling as that can damage the overrunning clutch. You want to come to a stop before you shift back into first so you dont have to worry about doing any damage. Ron
Re: Operating a RMVB on the street [Re: maximum entropy] #1079693
09/21/11 07:40 PM
09/21/11 07:40 PM
organ
organ
duh, i reread your post. mine is lba.
Re: Operating a RMVB on the street [Re: maximum entropy] #1079694
09/22/11 12:28 AM
09/22/11 12:28 AM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
I found that it would be best dropping the trans into first gear when the car was at a complete stop. I would always take off in first and quickly shift through to top gear once the car was moving if just cruising. Most of the time when the car was out, I was test driving as the owner didn't have a license. The trans had a Griner reverse pattern manual valve body, in a VG Coupe with a 360 backed by a 4800-5000 convertor. IHTH's
Alan Jones
Re: Operating a RMVB on the street [Re: Guitar Jones] #1079695
09/22/11 05:55 AM
09/22/11 05:55 AM
Moparmal Offline OP
Moparmal  Offline OP
Because I sometimes transport young children ad nervous passengers in the car and would like to make the trip as soon as smooth as possible for them in traffic.
Because it came with the Pro Race trans from CRT - John recommends them for a better line pressure - and I destroyed my 904 because the 450 pft the engine makes was too much for the Stage 2 fwd pattern.
And the car gets raced...
And the car sees 5000 road miles a year.
Good advice - thanks.
It does - thanks for the concern Ron.
harden up princess
Thanks Tex! See answer one, cutie pie....
No worries Al...thats the other option I guess.
Thanks for all the responses - the car performs a lot of different roles for us so all driving styles have to be accomodated.
Re: Operating a RMVB on the street [Re: Moparmal] #1079696
09/22/11 06:43 PM
09/22/11 06:43 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
hey Mal,
with my griner the higher the RPM the easier the shift i try not to shift under 25/2800.otherwise sometimes it feels like the something is trying to escape from under the car
Tex
New best MPH 130.32
Re: Operating a RMVB on the street [Re: tex013] #1079697
09/22/11 07:15 PM
09/22/11 07:15 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
All this eugh eoig uhg about low band apply.
Stock transmissions are low band apply. You shift them into 1 if you want to be in first rolling or stopped. The same thing happens you go into low or what I call 1st. If you are used to a non low band apply that will roll free you need to change your driving habits. Just don't put it in a gear that it can't handle at the speed you are going.
And if you simply don't understand how to drive buy and engine that can handle the occassional 70 MPH shift into 1st. LOL
Leon
Re: Operating a RMVB on the street [Re: Leon441] #1079698
09/23/11 10:38 AM
09/23/11 10:38 AM
BradH Offline
BradH  Offline
Uhhhh... what's the English translation for "eugh eoig uhg"?
Re: Operating a RMVB on the street [Re: Leon441] #1079699
09/23/11 10:43 AM
09/23/11 10:43 AM
BradH Offline
BradH  Offline
I run a Turbo Action FMVB w/o low-band apply on the street.
1. I always leave from a dead stop in 1st.
2. I always put it in neutral when I come to full stop like a red traffic light (no sense in putting any more heat in the fluid than necessary).
3. I always wait until I've come to a complete stop to put it into 1st when shifting down from a higher gear.
Like somebody else said above, either change your driving technique to accomodate the different valve body, or don't put a manual valve body in it.
