whats the bigest wheel/tire you can put on 74 duster #1079614
09/21/11 01:21 AM
09/21/11 01:21 AM
Central Missouri Fort Leonard...
mopar65 Offline OP
mopar65  Offline OP
well i am going to start building a 74 plymouth duster.so frist question is what is the bigest wheel tire combo that you can put on the back of a 74 duster with everything in the stock location?I would like to put a 15x10 weld prostar and a m/t 315/60/15 drag radiel tire on it. but not sure if it would fit.so just checking to see if anybody has done it etc.thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: whats the bigest wheel/tire you can put on 74 duster [Re: mopar65] #1079615
09/21/11 02:16 AM
09/21/11 02:16 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
28x10.5 and that is tight, 10' wheel with 4.5 BS,
Re: whats the bigest wheel/tire you can put on 74 duster [Re: mopar65] #1079616
09/21/11 09:14 AM
09/21/11 09:14 AM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
Bobby, I don't think you can get a 10" rim on it without moving the spring in. My Duster was mini tubbed with the spring moved into the frame, stock width 8 3/4, and had a 29x10.5W on a 10" Pro Star. The front lower edge of the wheel well had to be trimmed too.
Re: whats the bigest wheel/tire you can put on 74 duster [Re: Dart1031] #1079617
09/21/11 09:24 AM
09/21/11 09:24 AM
ill
dennismopar73 Offline
ill
cant get 10" on stock location,!! tire will hit wheel well and spring,
something has to move,ie spring inwards,
the 28 tall tire the rear end must be moved back about 1 -1.5 inch to clear the front 1/4 panel tried on 2 of my dusters, was the only way,
correct on 4.5 back space tho!
Re: whats the bigest wheel/tire you can put on 74 duster [Re: dennismopar73] #1079618
09/21/11 10:11 AM
09/21/11 10:11 AM
upstate new york
71cuda Offline
71cuda  Offline
upstate new york
on my 75 i put a 1/2" plate between the the front spring bracket and mount. i run a 28 x 11.5 dot.(same as a 9" slick)rim is a 8" with a 4"back space.i run hd springs.i can put a wider tire,but it would stick out past the wheel well.
Re: whats the bigest wheel/tire you can put on 74 duster [Re: 71cuda] #1079619
09/21/11 11:40 AM
09/21/11 11:40 AM
mopar65 Offline OP
mopar65  Offline OP
ok thanks for the info guys. I guess i will just have to minni tub and move the springs in on the duster before i buy new wheels and tires.again thanks for the help . Mopar65
Re: whats the bigest wheel/tire you can put on 74 duster [Re: mopar65] #1079620
09/21/11 09:31 PM
09/21/11 09:31 PM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
Check out this link' go to post#18 by 7172Duster It has 10 inch rims. Most Dusters you have to trim the front lip to use any tire taller then 28.5 to 29 inches...Keefe
http://www.forabodiesonly.com/mopar/showthread.php?t=14254
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
Re: whats the bigest wheel/tire you can put on 74 duster [Re: keefe] #1079621
09/22/11 07:01 AM
09/22/11 07:01 AM
Guitar Jones Online laugh2
My Duster has been mini tubbed and the springs moved into the frame rail. 10" Prostar with 6.5 back space, MT 29.5/11.5 or the 29.5/10.5W fits with tweaking to the front wheel opening. It all tucks into the wheel well too so the tire isn't sticking out. Wish I could find a pic but I lost them all. I'd take another pic for you but it's stored in the trailer without and engine right now so that's a PITA.
Biggest [Re: Guitar Jones] #1079622
09/22/11 02:06 PM
09/22/11 02:06 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
The largest I could fit w/o the tire sticking out past the wheelwell is a 15x8.5. Tire size is 255/60-15.
Re: whats the bigest wheel/tire you can put on 74 duster [Re: Guitar Jones] #1079623
09/22/11 02:40 PM
09/22/11 02:40 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
I've got a '75 Duster and I was able to get a 28/10.5 M/T ET Drag under it on an 8" rim (5.5 backspace) with no modifications. I was using a '68 B body 8 3/4 (60.125" drum to drum). I had right at a 5/8" between the tire and spring.
I have since move to a Dana that I cut to 54" (disc to disc). I now use a 10" rim (3.5" backspace) and for now the same 28/10.5 tire. I switched to an offset shackle that is not only offset but moves the rearend back an 1" which helped with the additional length of the Dana. I have much more clearance to the spring now and can probably use a 29/11.5 QTP.
If you need a rear end and rims, all that I took out is for sale.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: whats the bigest wheel/tire you can put on 74 duster [Re: clovis] #1079624
09/22/11 08:59 PM
09/22/11 08:59 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
factory a-body rear with dr. diff axles, mini-tub, springs moved, 325/50r15 on 15x10.25 w/ 7.5bs
