Re: whats the bigest wheel/tire you can put on 74 duster
[Re: Dart1031]
#1079617
09/21/11 09:24 AM
09/21/11 09:24 AM
Posts: 2,177 ill
dennismopar73
ill
cant get 10" on stock location,!! tire will hit wheel well and spring, something has to move,ie spring inwards, the 28 tall tire the rear end must be moved back about 1 -1.5 inch to clear the front 1/4 panel tried on 2 of my dusters, was the only way, correct on 4.5 back space tho!
[Re: keefe]
#1079621
09/22/11 07:01 AM
09/22/11 07:01 AM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
My Duster has been mini tubbed and the springs moved into the frame rail. 10" Prostar with 6.5 back space, MT 29.5/11.5 or the 29.5/10.5W fits with tweaking to the front wheel opening. It all tucks into the wheel well too so the tire isn't sticking out. Wish I could find a pic but I lost them all. I'd take another pic for you but it's stored in the trailer without and engine right now so that's a PITA.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#1079623
09/22/11 02:40 PM
09/22/11 02:40 PM
Posts: 553 Kentucky
clovis
Kentucky
I've got a '75 Duster and I was able to get a 28/10.5 M/T ET Drag under it on an 8" rim (5.5 backspace) with no modifications. I was using a '68 B body 8 3/4 (60.125" drum to drum). I had right at a 5/8" between the tire and spring. I have since move to a Dana that I cut to 54" (disc to disc). I now use a 10" rim (3.5" backspace) and for now the same 28/10.5 tire. I switched to an offset shackle that is not only offset but moves the rearend back an 1" which helped with the additional length of the Dana. I have much more clearance to the spring now and can probably use a 29/11.5 QTP. If you need a rear end and rims, all that I took out is for sale.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
