Reverse pattern shifter in Challenger suggestions?? #1079477
09/20/11 09:52 PM
09/20/11 09:52 PM
Ohio
fiddlestix Offline OP
Ohio
I am looking for a reverse pattern shifter I can mount in my stock console in a 70 Challenger with little modification. Any ideas? I was told that a rear mounted cable worked better. Is this true? Any help or suggestions would be greatly appreciated. Pictures would be even better.
Re: Reverse pattern shifter in Challenger suggestions?? [Re: fiddlestix] #1079478
09/21/11 12:33 AM
09/21/11 12:33 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
What's wrong with the stock shifter? Can't you file the detents like you do on a column shift?
Re: Reverse pattern shifter in Challenger suggestions?? [Re: 52savoy] #1079479
09/21/11 06:26 AM
09/21/11 06:26 AM
Ohio
Ohio
I don't really like the idea of pushing the button on the slapstick shifter to get to 3rd gear or low as it would be on a regular pattern. I was told this is how some people do it with this shifter.
