-1 heads ? #1079440
09/20/11 08:17 PM
09/20/11 08:17 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Is it okay to use some sort of locite on the studs that holds the rocker shafts down onto the heads? .Thax
Re: -1 heads ? [Re: racerx] #1079441
09/20/11 08:28 PM
09/20/11 08:28 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
oil or molly lube
if you use loctite and it hardens it a cusion inbetween the threads and would lose tourqe after awaile
1.39 9.85 - 137 mph
Re: -1 heads ? [Re: racerx] #1079442
09/20/11 08:43 PM
09/20/11 08:43 PM
NC
440Jim Offline
440Jim  Offline
NC
I never used any loctite. I just hand tighten the studs, then put the rockers shafts and holddowns on with the nuts and torqued to final.
Re: -1 heads ? [Re: 440Jim] #1079443
09/20/11 09:22 PM
09/20/11 09:22 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thax....Fellas reason I'm asking is on several occasions when i disassemble the rockers i've notice that a few of the studs were loose and had back out a few threads.....
Re: -1 heads ? [Re: racerx] #1079444
09/20/11 10:07 PM
09/20/11 10:07 PM
AndyF Offline
AndyF  Offline
You might need larger diameter pushrods.
Re: -1 heads ? [Re: 440Jim] #1079445
09/20/11 10:11 PM
09/20/11 10:11 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
x2
Mopar Performance
Re: -1 heads ? [Re: AndyF] #1079446
09/20/11 10:49 PM
09/20/11 10:49 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Please explain Andyf
Re: -1 heads ? [Re: moparniac] #1079447
09/21/11 04:14 AM
09/21/11 04:14 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
x2
x3
Re: -1 heads ? [Re: racerx] #1079448
09/21/11 11:56 AM
09/21/11 11:56 AM
AndyF Offline
AndyF  Offline
If the rocker studs are moving around then something is making them move. Most likely suspect is that your pushrods are not stiff enough. Call Manton and tell him what springs you are using, what RPM you're running and ask him what you need.
Re: -1 heads ? [Re: AndyF] #1079449
09/21/11 12:20 PM
09/21/11 12:20 PM
Re: -1 heads ? [Re: Cab_Burge] #1079450
09/21/11 02:20 PM
09/21/11 02:20 PM
AndyF Offline
AndyF  Offline
If that is a dead end then maybe your rocker shafts aren't stiff enough for the load. Step up to a thicker wall rocker shaft and things might stay together better.
Re: -1 heads ? [Re: AndyF] #1079451
09/22/11 01:40 AM
09/22/11 01:40 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
I have a set of push rods on order(smith Brothers)and discussing my combo with him he recommend the .120 wall thickness for my combo the old rods were .083.Don't no what the wall thickness on the Harland Sharpe r shafts r though
Re: -1 heads ? [Re: racerx] #1079452
09/22/11 05:13 PM
09/22/11 05:13 PM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
The harland sharp shafts are definitely NOT the problem, they are very thick and rigid.
from here I cant go back and see what you are using for hold downs (will assume the harland sharp hold downs too) no problem with those either. and bolts or studs?
Re: -1 heads ? [Re: bumps440] #1079453
09/22/11 07:04 PM
09/22/11 07:04 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
The old setup were indys.The ones r Harlands(which i have not installed yet).......Thax
