Re: -1 heads ?
[Re: racerx]
#1079441
09/20/11 08:28 PM
09/20/11 08:28 PM
Posts: 5,618 long island NY
Ari440
long island NY
oil or molly lube
if you use loctite and it hardens it a cusion inbetween the threads and would lose tourqe after awaile
1.39 9.85 - 137 mph
Re: -1 heads ?
[Re: AndyF]
#1079446
09/20/11 10:49 PM
09/20/11 10:49 PM
Posts: 4,071 Mo.
racerx
Mo.
You might need larger diameter pushrods.
Please explain Andyf
Re: -1 heads ?
[Re: moparniac]
#1079447
09/21/11 04:14 AM
09/21/11 04:14 AM
Posts: 4,647 aotearoa
rebel
aotearoa
I never used any loctite. I just hand tighten the studs, then put the rockers shafts and holddowns on with the nuts and torqued to final.
x2
x3
Re: -1 heads ?
[Re: racerx]
#1079452
09/22/11 05:13 PM
09/22/11 05:13 PM
Posts: 1,170 Westbury, NY
bumps440
super gas
super gas
Westbury, NY
I have a set of push rods on order(smith Brothers)and discussing my combo with him he recommend the .120 wall thickness for my combo the old rods were .083.Don't no what the wall thickness on the Harland Sharpe r shafts r though
The harland sharp shafts are definitely NOT the problem, they are very thick and rigid. from here I cant go back and see what you are using for hold downs (will assume the harland sharp hold downs too) no problem with those either. and bolts or studs?
Re: -1 heads ?
[Re: bumps440]
#1079453
09/22/11 07:04 PM
09/22/11 07:04 PM
Posts: 4,071 Mo.
racerx
Mo.
The old setup were indys.The ones r Harlands(which i have not installed yet).......Thax
