Re: hyd lifter missing the retaining spring? is it junk now
[Re: goldmember]
#1079262
09/20/11 04:38 PM
09/20/11 04:38 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
The clip is there to keep the lifter together during shipping/installation.During normal operation the cup never contacts the snap ring,so it's just hanging around doing nothing. I would replace the wire type retainer with a C clip type in any hyd combo that will be run with lash,whether intentional or not.
I had a hyd. lifter lose it's wire ring, the cup got jammed sideways and took out the cam because it stopped spinning.
[Re: dirt]
#1079263
09/20/11 04:41 PM
09/20/11 04:41 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
If the hyd lifter is used with preload on the base circle and your not lofting the lifter over the nose it will not have any effect. Of course setting preload is done with the clip in place as a starting point,then preload is added to keep the cup down from the weak wire retainer and allow quiet operation. Valve spring pressure won't(SHOULD NOT) allow the cup to escape the lifter body.
[Re: goldmember]
#1079265
09/21/11 09:47 AM
09/21/11 09:47 AM
JohnRR
U.S.S.A.
I could see that happening with the sheet metal type cups used in some lifters,if the valve train is having issues bad enough to kick the retainer out. Most of the hyd lifters I work with have cups near .200" tall and .001" clearance to the lifter body,they don't have any chance of laying over.
I never checked the size of the cup, the lifter was one supplied with the purple cam that was in the motor when I bought it.
