Re: Why an alum. driveshaft?
[Re: rod440]
#1079206
09/20/11 12:37 PM
09/20/11 12:37 PM
RapidRobert
Good: Would save a fair amount of weight. Hype: wouldn't take 10 less horsepower to rotate it as opposed to a steel one
[Re: RapidRobert]
#1079207
09/20/11 02:14 PM
09/20/11 02:14 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
What about the ability to flex more before breakage? I had a driveshaft made for my truck...75.5 inch center to center between the front and rear joints. It's 5 inch diameter tube. All aluminum. it's definitely light for it's size and is supposed to be very strong. I was told it couldnt be made of chromoly, but I dont know what the reasoning was.
[Re: POS Dakota]
#1079208
09/20/11 02:32 PM
09/20/11 02:32 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
I remember hearing from someone on a Craftsman Truck Series team that they found their lightweight driveshafts were whipping/flexing on the chassis dyno. That flexing cost HP. So you can go too light, not cause breakage, but not gain the HP you 'think' you should.
[Re: jcc]
#1079215
09/20/11 09:46 PM
09/20/11 09:46 PM
Challenger 1
Cincinnati, Ohio
It's not clear to me if you are suggesting the lack of "turn down' makes for a stronger driveshaft. i don't know, but if one used a high tech axle shaft as an example, that down turn might be an engineering plus, or just an OEM move to save money.
I was only pointing it out. I have no idea if it's best or not? When I first saw it I was worried about muffler clearance because of lack of turn down. Thinking about it I'm sure it's cheaper. I bet if I ordered steel I would have got the same thing? It fit's, it clears and don't vibrate for just 2-300 bucks in 2006 if I remember right? I would think a lighter drive shaft would be easier on trans tailshaft bushings and I'm always looking to save weight, always if I'm putting fuel in it. I bet it could handle quite a bit on the strip. Came from Cincinnat Driveline and Hydralics. Have known the owner for many years before he even started his own company from being in the truck repair business. He used to be in Northside working for someone else selling driveline stuff a long time ago. lol. Cinti driveline
[Re: savoy64]
#1079217
09/21/11 06:46 AM
09/21/11 06:46 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
i picked up an aluminum driveshaft from a 96? dodge van at the pickapart--had it shortened ($100) and run it under my 64---bob
I dont suppose the yoke will just slide into my 833 no issues will it...???
Does that have the larger 7290 U-joints...???
This would make things too easy. My 70 Challenger needs a shaft...
