Would a B body 65-67 8 3/4 rear axle work on a 69 Dart #1078760
09/19/11 11:18 PM
09/19/11 11:18 PM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
I have a 1965-1967 B body 8 3/4 rear axle and was thinking of putting in a 1969 Dart
B body axle measures--54 1/4 flange to flange where an A body is 52 5/8
I recognize the spring perches need to be moved in by 1/2" on either side
Would this work
Re: Would a B body 65-67 8 3/4 rear axle work on a 69 Dart [Re: Dart6pak] #1078761
09/19/11 11:32 PM
09/19/11 11:32 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
You could get the axle to fit, but you would likely need to get rear wheels with more back spacing to make up for the extra width.
Re: Would a B body 65-67 8 3/4 rear axle work on a 69 Dart [Re: Dart6pak] #1078762
09/20/11 12:42 AM
09/20/11 12:42 AM
AndyF Offline
AndyF  Offline
Should work fine with some Mustang wheels. 17x8 with 5.72 BS usually fits that rear end in an early A body.
