Brake rotor interchange for my 1971 bee UPDATED PICS #1078729
09/19/11 10:30 PM
09/19/11 10:30 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
I was just at a yard today and they have a ton of 1968 to 1974 mopars B and C bodies with disc brakes. What will interchange with my 1971 Superbee? Will c bodies work? I was going to bring my michromiter out and find the best pair but I wonder what will interchange?
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Brake rotor interchange for my 1971 Superbee [Re: TX9H6E4CUDA] #1078730
09/19/11 10:53 PM
09/19/11 10:53 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Is your Superbee allready a disc brake car?
The only rotors that will readily interchange will be from 70, 71, 72, B & E body cars.
C body stuff doesn't work. Everything is way to big.
But, if your doing a complete disc brake swap, lotsa A, B, E, F, M, J, body cars from 1973 up, are the way to go.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Brake rotor interchange for my 1971 Superbee [Re: hemi71x] #1078731
09/19/11 11:02 PM
09/19/11 11:02 PM
minnarusta
minnarusta
Yeah its a original disc brake car. The rotors I have are ok but I would love to have a extra set for the car and maybe find a better pair. I can't buy new because they are so overpriced.
Re: Brake rotor interchange for my 1971 Superbee [Re: TX9H6E4CUDA] #1078732
09/19/11 11:39 PM
09/19/11 11:39 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Dr.Diff sells a special race for the inner bearing,so you can run the one peice later model brake rotors,on your 70/71 disc brake spindles. The later rotors cost about 45 bucks a peice. I always order rotors for a 73/74 Charger.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Brake rotor interchange for my 1971 Superbee [Re: chargervert] #1078733
09/20/11 12:30 AM
09/20/11 12:30 AM
minnarusta
minnarusta
Ok two piece rotors? My superbee has rotors that look like they are one piece and ill take pictures of the ones I have.
Re: Brake rotor interchange for my 1971 Superbee [Re: TX9H6E4CUDA] #1078734
09/20/11 06:15 AM
09/20/11 06:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes stock on your car would be a 2 piece rotor .
Re: Brake rotor interchange for my 1971 Superbee [Re: JohnRR] #1078735
09/20/11 11:05 AM
09/20/11 11:05 AM
minnarusta
minnarusta
Well here were the rotors that were on my car. Ive seen the two piece rotors before and these don't look like those. Are these the later versions and maybe my car was converted before I got it?
Yeah I don't see anywhere it is a two piece set up.
Re: Brake rotor interchange for my 1971 Superbee [Re: TX9H6E4CUDA] #1078736
09/20/11 11:22 AM
09/20/11 11:22 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What type of caliper , stock should be a pin type , also what bearing # is in the rear ?
Re: Brake rotor interchange for my 1971 Superbee [Re: JohnRR] #1078737
09/20/11 11:37 AM
09/20/11 11:37 AM
minnarusta
minnarusta
Yes John it has the pin type caliper and sorry I don't have the bearing in front of me right now. I can get that info later today.
Re: Brake rotor interchange for my 1971 Superbee [Re: TX9H6E4CUDA] #1078738
09/20/11 12:21 PM
09/20/11 12:21 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That is a '73 and newer A,B,E,F,M,J body rotor
