Page 3 of 3 1 2 3
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: 69CoronetRT] #1078299
11/18/11 10:22 PM
11/18/11 10:22 PM
Mid-Atlantic
Scatransit Offline
Scatransit  Offline
Mid-Atlantic
I'd be interested in seeing those sources. Are they factory sources or aftermarket? Can you post them?
These are factory/dealer...here ya go...
[oo]======[oo]
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: Scatransit] #1078300
11/18/11 10:22 PM
11/18/11 10:22 PM
Mid-Atlantic
Scatransit Offline
Scatransit  Offline
Mid-Atlantic
more...
[oo]======[oo]
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: Scatransit] #1078301
11/18/11 10:44 PM
11/18/11 10:44 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
What's the difference between the standard 4-speed transmission and the Heavy Duty 4-speed transmission? And is the "Hemi" 4-speed the same as the Heavy Duty 4-speed??
Seems the A33 and A34 option is keyed off of the HD 4-speed and the axle ratio and the 4.10 gets power disc brakes.
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: Scatransit] #1078302
11/18/11 10:45 PM
11/18/11 10:45 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
more...
Must be a mistake in the listing because there is no standard axle listed for the 440 with manual trans. Only optional rears.
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: RoadRunnerJD] #1078303
11/18/11 10:55 PM
11/18/11 10:55 PM
Mid-Atlantic
Scatransit Offline
Scatransit  Offline
Mid-Atlantic
It was always my understanding that with respect to the GTX, RT, & 440/426 Charger, there was no standard axle when ordering a 4 speed...You had a choice of the two axle packages, and that was it.
[oo]======[oo]
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: Scatransit] #1078304
11/18/11 11:24 PM
11/18/11 11:24 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
But the 440/426 4-speed "required" a Dana, didn't it? What if you did't want a 3.54/3.55 or 4.10 ratio could you get a Dana with a 3.23 or other ratio?
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: A12] #1078305
11/18/11 11:39 PM
11/18/11 11:39 PM
Warrenton, VA
Warrenton, VA
You had to get an automatic.
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: A12] #1078306
11/18/11 11:45 PM
11/18/11 11:45 PM
Warrenton, VA
Warrenton, VA
The 055 radiator now cleaned and painted, with the 305 8 (October 31, 1968) date code. The GTX has a C16/December 16, 1968 Scheduled Production Date so it is close enough to be the original and I still believe it is the original radiator to the car.
Why didn't you keep the original California air cleaner on the car? Are you installing chrome exhaust tips?
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: RoadRunnerJD] #1078307
11/19/11 01:17 AM
11/19/11 01:17 AM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Don't want to go OT but I like the sound of the unsilenced air cleaner cover and the exhaust tips and even thinking about putting an "air grabber" system on it. Had the dual snorkel on it.....another thing is that darn big dual snorkel air filter cover his HEAVY too and I'm sure it doesn't flow enough air to feed the Holley 770 under the unsilenced cover on there now took the stock road wheels off and going to redo them, put a set of G-70 red lines on them and go do a pure stock event or two......do I have to put the dual snorkel cover back on for that
Oh this is the GTX with the 055 radiator, 4-speed, 3.54 Dana to keep this OT
MikeR
Day Two now with the tips
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: Scatransit] #1078308
11/19/11 02:31 AM
11/19/11 02:31 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
more...
Very cool. thanks.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: 69CoronetRT] #1078309
11/19/11 08:29 AM
11/19/11 08:29 AM
Mid-Atlantic
Scatransit Offline
Scatransit  Offline
Mid-Atlantic
So I guess we can conclude from this that the 26" radiator used in axle packages is not always the max cooling unit. I also looked in Galen's parts book and, sure enough, the 055 was used in 440 powered 4-speed b-bodys "less max cooling". The only other application was for a/c cars. I guess max cooling and axle packages don't go hand-in-hand in this instance. Still, one has to wonder why...... life is a mystery....
[oo]======[oo]
Re: 055 & 054 '69 RADIATORS are they both 3-row rads? [Re: Scatransit] #1078310
11/21/11 01:08 PM
11/21/11 01:08 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
It all makes perfect sense to me except if the 8 3/4 cars with 3.55's got the 054....that's odd. I suppose the rationalization is that 3.55 is an optional axle package gear on the 383 cars (standard is 3.23) where the 3.54 is the "standard" gear with the 440-4spd.... Doesn't make any sense from an engineering perspective, but it does have some twisted logic from a sales perspective.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Page 3 of 3 1 2 3
