Rust on 69 Dart?? #1078044
09/19/11 11:05 AM
09/19/11 11:05 AM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
If you were looking for rust on a 69 Dart other than the floors and frame where would you look? Where is the most common places? Are they like the b-body around the back glass? Thanks
Re: Rust on 69 Dart?? [Re: bobs69] #1078045
09/19/11 11:13 AM
09/19/11 11:13 AM
ill
dennismopar73 Offline
ill
look at the upper control arms mounting on the fram, as well as inside frame by the steering gear box area, , and then the tourqu box area crossmount,
Re: Rust on 69 Dart?? [Re: dennismopar73] #1078046
09/19/11 11:58 AM
09/19/11 11:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Inner fenders where the fenders bolt on and back by the firewall ....
Re: Rust on 69 Dart?? [Re: JohnRR] #1078047
09/19/11 12:11 PM
09/19/11 12:11 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
EVERYWHERE!
JB Rhinehart, Realist
A-Body's RULE!
Re: Rust on 69 Dart?? [Re: Rhinodart] #1078048
09/19/11 04:11 PM
09/19/11 04:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
EVERYWHERE!
Re: Rust on 69 Dart?? [Re: JohnRR] #1078049
09/19/11 06:27 PM
09/19/11 06:27 PM
Round Rock,Tx
N
Nirvana Offline
Nirvana  Offline
N
Round Rock,Tx
Cowl,and the trunk channel/gutter.
87 D100 225 4 speed.
Re: Rust on 69 Dart?? [Re: bobs69] #1078050
09/19/11 06:50 PM
09/19/11 06:50 PM
Mansfield, TEXAS
JOES4FORTY Offline
JOES4FORTY  Offline
Mansfield, TEXAS
The spare tire well and the bottom of the quarters behind the rear wheels.
The GTS Registry!
MOPARTS MEMBER IN PRINT
1969 Dart GTS LS23P9B (First day of production car money pit)
Re: Rust on 69 Dart?? [Re: bobs69] #1078051
09/19/11 08:17 PM
09/19/11 08:17 PM
Sec.414,seat 12,White Sox Park
swapman Offline
swapman  Offline
Don't you mean,Where do you find the 69 DART on the Rust?
Re: Rust on 69 Dart?? [Re: bobs69] #1078052
09/20/11 12:25 AM
09/20/11 12:25 AM
Mansfield, TEXAS
JOES4FORTY Offline
JOES4FORTY  Offline
Mansfield, TEXAS
I was fairly lucky on my Dart. It was a southern car and just the trunk extensions, bottom of the quarters and spare tire well were cancered.
The GTS Registry!
Re: Rust on 69 Dart?? [Re: Rhinodart] #1078053
09/20/11 08:35 AM
09/20/11 08:35 AM
Columbus Ohio
mopfried Offline
mopfried  Offline
Columbus Ohio
EVERYWHERE!
Simple fact is LOOK EVERYWHERE. It depends on where the car came from and how it was cared for. I have been looking a A bodies for a while and they can rust anywhere. It is a 43 year old car. I have seen a few with good bodies and rotten frames.... I would spend a lot of time underneath one with a hammer and a good light before I would drop much money on one.
Re: Rust on 69 Dart?? [Re: bobs69] #1078054
09/20/11 08:31 PM
09/20/11 08:31 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
Pretty much anything made out of steel, on my old 68 Dart I was able to re-use the roof, cowl, 3 frame rails, 1 door, 1 inner fender and the dash, everything else was swapped for better parts from donor cars and the floors/trunk came from AMD.
The car didn't look all that bad it's just that every time I dug into it I found more hidden damage.
Re: Rust on 69 Dart?? [Re: bobs69] #1078055
09/22/11 01:03 AM
09/22/11 01:03 AM
Jacksonville Florida
elitecustombody Offline
bottom of quarters between door and wheelwell,lower front and rear glass corners ,front floor,trunk floor and extensions
