oil change #1077980
09/19/11 09:06 AM
09/19/11 09:06 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Getting ready to to put the car to bed for the winter. Is it better to change the oil before the storage and run on it next year or put it away then change the oil in the spring? Thanks
Re: oil change [Re: 70 buzz] #1077981
09/19/11 09:07 AM
09/19/11 09:07 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I do one before I put it up for the winter and one as soon as I get it home in the spring.
Re: oil change [Re: 70 buzz] #1077982
09/19/11 10:46 AM
09/19/11 10:46 AM
Yes as this lets metal be coated with fresh oil as opposed to acids & other impurity laden oil sitting on it undisturbed for several months. Change oil/filter/run it a minute to get everything coated
