Re: Car starts when key is RELEASED, why?
[Re: Alaskan_TA]
#1077397
09/18/11 06:35 PM
09/18/11 06:35 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
It could be a bad ballast resistor.
Actually no, his problem is the reverse of that. Bad ballast would start while cranking, then die when key is released.
[Re: MONC]
#1077399
09/18/11 06:38 PM
09/18/11 06:38 PM
Pacnorthcuda
Recently, my car starts when I release the key when it's cranking, not when it's in the run position. If I don't release the key car will just keep cranking.
This happen to anyone else? What is the cause of this?
Did you mean to say "not when it's in the START position"?
[Re: Pacnorthcuda]
#1077401
09/18/11 09:22 PM
09/18/11 09:22 PM
Posts: 3,656 The Historic Hudson Valley
MONC
Right, it won't start when I am holding the key in the start position and the car is cranking. Once I let go and it goes to the run position, the car starts.
I think I got my different positions right...
[Re: Pacnorthcuda]
#1077402
09/18/11 09:24 PM
09/18/11 09:24 PM
MONC
Your ignition power feed isn't sending juice to the coil during cranking, only in the run position. Could be a bulkhead connector issue.
So if this was the case, I could test this my checking for juice at the coil when cranking, correct?
[Re: MONC]
#1077403
09/18/11 09:32 PM
09/18/11 09:32 PM
Posts: 10,708 North Dakota
6PakBee
North Dakota
My '72 W200 does the same thing. On mine, if I turn it just until the starter cranks, it'll start. If you crank the switch hard against the 'start' position, it'll crank all day without starting. I tried to run it down once and the best I came up with was that the lock mechanism had worn so much that when you turn to 'start' hard, it allows the ignition switch to turn past the 'run' position.
[Re: mopar_man]
#1077406
09/19/11 10:38 AM
09/19/11 10:38 AM
MONC
You have a dual side resistor and the start side is open. Pull the spade connectors off the resistor and put the two wires that are on the top on the bottom and vice versa. Now if your car starts while the key is in the start position and shuts down in the run position.....you have found the problem.
Not sure where ( what part) you are talking to pull spade connectors from, can you please explain further, thanks.
[Re: TooMany62s]
#1077407
09/19/11 10:39 AM
09/19/11 10:39 AM
MONC
I just went through the same thing with one of my cars. In my case it was the ignition switch.
I just changed the ignition switch ( I was having this issue before I changed it though ).
[Re: JohnRR]
#1077410
09/19/11 01:27 PM
09/19/11 01:27 PM
MONC
More info ... what year is the car , electronic or points ?? before I can make an ASSumption of the problem .
70 E body - electronic ignition.
[Re: MONC]
#1077413
09/19/11 04:10 PM
09/19/11 04:10 PM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
Does it have a 2 prong Ballast or a 4 prong ?
