Page 1 of 10 1 2 3 9 10
Car starts when key is RELEASED, why? * -UPDATE 11/5 #1077394
09/18/11 06:29 PM
09/18/11 06:29 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
Recently, my car starts when I release the key when it's cranking, not when it's in the run position. If I don't release the key car will just keep cranking.
This happen to anyone else? What is the cause of this?
Re: Car starts when key is RELEASED, why? [Re: MONC] #1077395
09/18/11 06:33 PM
09/18/11 06:33 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It could be a bad ballast resistor.
Re: Car starts when key is RELEASED, why? [Re: MONC] #1077396
09/18/11 06:34 PM
09/18/11 06:34 PM
Kirkland, Washington
Pacnorthcuda Offline
Your ignition power feed isn't sending juice to the coil during cranking, only in the run position. Could be a bulkhead connector issue.
Re: Car starts when key is RELEASED, why? [Re: Alaskan_TA] #1077397
09/18/11 06:35 PM
09/18/11 06:35 PM
Actually no, his problem is the reverse of that. Bad ballast would start while cranking, then die when key is released.
Re: Car starts when key is RELEASED, why? [Re: MONC] #1077398
09/18/11 06:36 PM
09/18/11 06:36 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
are you saying the key gets stuck in the start position and you have to move it to the run position?
Re: Car starts when key is RELEASED, why? [Re: MONC] #1077399
09/18/11 06:38 PM
09/18/11 06:38 PM
Did you mean to say "not when it's in the START position"?
Re: Car starts when key is RELEASED, why? [Re: mikemee1331] #1077400
09/18/11 09:19 PM
09/18/11 09:19 PM
MONC Offline OP
MONC  Offline OP
No it does not get stuck it will release.
Re: Car starts when key is RELEASED, why? [Re: Pacnorthcuda] #1077401
09/18/11 09:22 PM
09/18/11 09:22 PM
MONC Offline OP
MONC  Offline OP
Right, it won't start when I am holding the key in the start position and the car is cranking.
Once I let go and it goes to the run position, the car starts.
I think I got my different positions right...
Re: Car starts when key is RELEASED, why? [Re: Pacnorthcuda] #1077402
09/18/11 09:24 PM
09/18/11 09:24 PM
MONC Offline OP
MONC  Offline OP
So if this was the case, I could test this my checking for juice at the coil when cranking, correct?
Re: Car starts when key is RELEASED, why? [Re: MONC] #1077403
09/18/11 09:32 PM
09/18/11 09:32 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
My '72 W200 does the same thing. On mine, if I turn it just until the starter cranks, it'll start. If you crank the switch hard against the 'start' position, it'll crank all day without starting. I tried to run it down once and the best I came up with was that the lock mechanism had worn so much that when you turn to 'start' hard, it allows the ignition switch to turn past the 'run' position.
Re: Car starts when key is RELEASED, why? [Re: 6PakBee] #1077404
09/18/11 11:48 PM
09/18/11 11:48 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
You have a dual side resistor and the start side is open. Pull the spade connectors off the resistor and put the two wires that are on the top on the bottom and vice versa.
Now if your car starts while the key is in the start position and shuts down in the run position.....you have found the problem.
Re: Car starts when key is RELEASED, why? [Re: mopar_man] #1077405
09/19/11 06:19 AM
09/19/11 06:19 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I just went through the same thing with one of my cars. In my case it was the ignition switch.
Re: Car starts when key is RELEASED, why? [Re: mopar_man] #1077406
09/19/11 10:38 AM
09/19/11 10:38 AM
MONC Offline OP
MONC  Offline OP
Not sure where ( what part) you are talking to pull spade connectors from, can you please explain further, thanks.
Re: Car starts when key is RELEASED, why? [Re: TooMany62s] #1077407
09/19/11 10:39 AM
09/19/11 10:39 AM
MONC Offline OP
MONC  Offline OP
I just changed the ignition switch ( I was having this issue before I changed it though ).
Re: Car starts when key is RELEASED, why? [Re: MONC] #1077408
09/19/11 11:04 AM
09/19/11 11:04 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
More info ... what year is the car , electronic or points ?? before I can make an ASSumption of the problem .
Re: Car starts when key is RELEASED, why? [Re: MONC] #1077409
09/19/11 11:42 AM
09/19/11 11:42 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Same here. I changed the switch out thinking it was the switch. No change in how it responded and continues to respond.
Re: Car starts when key is RELEASED, why? [Re: JohnRR] #1077410
09/19/11 01:27 PM
09/19/11 01:27 PM
MONC Offline OP
MONC  Offline OP
70 E body - electronic ignition.
Re: Car starts when key is RELEASED, why? [Re: MONC] #1077411
09/19/11 02:42 PM
09/19/11 02:42 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Funny this should come up, saves me a post. My buddies 73 chall factory electronic is doing the same thing.I did replace the ign switch last year and IIRC could not connect ALL the wires properly thru the banana column connectors as some well meaning "edisons" had added a FORD starter solenoid, God knows why, and done a few things outside the harness.Cranks normally, but no spark in the "cranking" position.(Makes ZERO ignition noises).I just noticed it only starts when you letta go the key.He, being a newbie, cannot remeber if it always did this or if it's a new thing. He did install a ne ballast a couple weeks ago.
Re: Car starts when key is RELEASED, why? [Re: Sixgun] #1077412
09/19/11 02:47 PM
09/19/11 02:47 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Cheat - install a push button switch to the 2 terminals on the starter relay and mount on the lip of the dash. Yeah I know it is not right but it works and is a semi theft deterrent. Turn key and push button to start.
Re: Car starts when key is RELEASED, why? [Re: MONC] #1077413
09/19/11 04:10 PM
09/19/11 04:10 PM
U.S.S.A.
U.S.S.A.
Does it have a 2 prong Ballast or a 4 prong ?
