Re: Help with a 340 engine
[Re: stumpy]
#1077380
09/18/11 06:06 PM
09/18/11 06:06 PM
RapidRobert
breakin oil(zinc), moly paste on the lobes/lifter bottoms, spring pressure, breakin procedure, too much cranking on initial fireup, lifters too tight in bores, defective cam or lifters. where are you at with those?
[Re: halory]
#1077381
09/18/11 06:09 PM
09/18/11 06:09 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I built a 340 stroker (408). Used a 292 duration 508 lift hydraulic cam, with edelbrock heads 273 adjustable rockers with the stock pushrods (the 273 was a solid lift motor). Wiped out the cam in 500 miles. Why do you think the cam wiped out? Are the push rods to long for hydraulic lifters?
Yes, stock 273 solid lifter push rods are nearly a quarter of an inch too long. You need push rods made for a hydraulic lifter engine using adjustable rockers.
