Re: holley carb idle problem
[Re: anmracing]
#107689
08/20/08 10:10 AM
08/20/08 10:10 AM
RapidRobert
with the carb off the car would the throttle blades close completely?
[Re: superbyrd]
#107691
08/20/08 10:20 AM
08/20/08 10:20 AM
RapidRobert
the carb is good by itself,thats good.are the blades hanging up on the base gasket? if you set it down on the intake it's good? & when you tighten up the mounting bolts it ends up binding?
[Re: superbyrd]
#107695
08/21/08 04:20 AM
08/21/08 04:20 AM
Posts: 10,693 Surface of the Sun, AZ
Hotwheelsjr
got it fixed. loosened the the blades,adjusted them slightly,which allowed the blades and shafts to close all the way. now i have idle screw adjustment,and car idles smooth as a mothers love. thanks for the input.
As I was reading your post and the first few comments, my first impression was that the butterflies were not closing all the way. I've had the same prob with cheap gaskets on a six pack.
