Re: Stripping car to bare metal for paint and need help.
[Re: Challenger 1]
#1076906
09/18/11 11:23 AM
09/18/11 11:23 AM
Posts: 2,766 Appleton, Wisconsin
rtmike
Appleton, Wisconsin
I spent a whole weekend stripping the paint from my engine compartment, but my car is a shell, nothing bolted on it. Probably the best advise is above. A little degreaser in the pressure washer would help to I bet.
Its not primer its perma gray.
[Re: Silverbullet2]
#1076910
09/18/11 08:23 PM
09/18/11 08:23 PM
Posts: 35 Utah
BelvedereCruisin
Utah
I'd blast it and give it a good coat of epoxy primer. That'll stabilize it for a while.
Sadly I don't have the money to get it blasted.
It looks like the overall consensus is to remove the surface rust and hit it with some epoxy primer.
Can I spray that over existing paint as well? As in the paint in the engine compartment and trunk.
Also, do I need to rough the metal up(40 or 80 grit) before spraying epoxy?
[Re: lahatte]
#1076914
09/19/11 01:33 AM
09/19/11 01:33 AM
Posts: 35 Utah
BelvedereCruisin
Utah
Do you have a good sized air compressor? If so, and if you are so inclined, you might think about getting a pressure blaster from Harbor Freight, or similar. Probably less then $200. Fine sand should be available at local hardware stores.
I was told that blasting was a major pain due to all the fine sand you have to clean up afterwards. Is that true? What are you thoughts on that?
[Re: BelvedereCruisin]
#1076915
09/19/11 08:32 AM
09/19/11 08:32 AM
Challenger 1
Cincinnati, Ohio
Terrible idea, because you don't have near enough compressor, no knowledge on how to do it and your car is not completely stripped of every nut and bolt.
#1076916
09/19/11 12:34 PM
09/19/11 12:34 PM
Posts: 1,047 Arizona
68CoronetRT
Arizona
I have a '66 Belvedere II convertible. The engine is pulled and most of the paint is stripped to bare metal, all except the engine compartment and the trunk.
Question 1: Since I don't have a lot of money or skill, should I leave the engine compartment and trunk with the old paint? Can I just have the body/paint guy paint over it?
Question 2: This project has been going on for over 5 years. There has been some very light surface rust on the bare metal. I have been using a hard plastic wire attachment on my drill to remove it. Is there a faster way? Also, what should I do to protect the metal when I get it cleaned up?
This was supposed to be a project car with my dad(who knows cars inside and out), but he decided he didn't want to work on it with me. So now I am stuck trying to muddle through and complete this project. I appreciate any help offered/given.
Thanks!
With longer term projects your best bet is using epoxy primer on bare metal. It provides better rust and corrosion protection and when ready you can simply scuff it and apply more epoxy, filler, 2k primer/surfacer, or even base if finish sanded first.
Stripping the engine bay is the best idea and if you sandblast be sure to seal the rest of your car very well cause sand/media gets everywhere and is a bear to clean up. Paint strippers work great but be sure to neutralize by washing the area with plenty of soap and water paying special attention to seams. You won't want this stuff seeping out of any cracks and ruining your paint job.
One last thing. If you do leave the old paint on you will need to remove any rust or loose paint, scuff with a red scotchbrite pad to dull the surface and then cover with epoxy primer to lock it down.
