12 point roll cage weight #1076819
09/17/11 11:15 PM
09/17/11 11:15 PM
mo
ALKYW5DART Offline OP
mo
going to finally put a 12 point cage in my dart is the weight savings of moly over mild worth the money also about how much weight saving would be expected
Re: 12 point roll cage weight [Re: ALKYW5DART] #1076820
09/18/11 12:24 PM
09/18/11 12:24 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
You will save about 30 to 40 lbs, but at 3 times the cost.
Re: 12 point roll cage weight [Re: WheelsUp73] #1076821
09/18/11 01:17 PM
09/18/11 01:17 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
I cant quote prices but I doubt a CM cage is 3x or even 2x the cost of mild steel. Besides thre weight savings benefits, chromoly is much more desirable if you ever sell the car later.
I think a lot of chassis shops arent even doing MS anymore..
Re: 12 point roll cage weight [Re: WheelsUp73] #1076822
09/18/11 01:23 PM
09/18/11 01:23 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
WOW, 3x the cost??? I don't think so! My Art Morrison cage kit is Chromo, and it wasn't near 3X more for it over mild. And that is just the price of the kit, the install is the same price or less even. The guy that installed my cage prefered chromo, since it is cleaner to work with. I saved the extra cost of the chromo in the price of fabrication.
My chromo "8 point" (it is a 10 point, Art Morrison doesn't count the D Bars) was $520. Same cage in MS is $285. They hadn't done an Aspen before, so they went and found one, and measured it up. It took two weeks to be build, AND shipped to me in Canada.
The shipping weight was 104lbs. This included the 6x6 mounting plates. The kit also came with a drivers door sill bar, and a dash bar, which I used for sub frame connectors. 2x3 would have been better I guess, but with a 10 point cage in the car, it is very stiff.
Going to a 12 point is going to make your front suspension work better too. My next car will have an Art Morrison 12 point ( or 10 point as they call it)
Here are some prices to go off of. Phone the actual chassis companies for this kind of info. I too thought a chromo cage would be way more than a MS unit.
http://www.artmorrison.com/2006cat/54.pdf
-Kenny
Re: 12 point roll cage weight [Re: ALKYW5DART] #1076823
09/18/11 04:46 PM
09/18/11 04:46 PM
Alberta Canada
Alberta Canada
So, We all know the Chromo cage will be lighter, and numbers are always thrown out as to what the weight savings is. However I have never seen any actually calculations on it. Since today is Sunday, and I am bored, I figured I would nerd out, and do some math for fun.
I went out the the garage and pulled the tarp back on my 1967 Plymouth Valiant that is currently playing the role of my spare shelf holding up old clothes, empty boxes, etc. I roughly measured out the tubing that would be needed to make a 12 point cage in the car. I figure I would need about 740" of tubing.
I am going to abbreviate some of these down.
A1= Area of tubing using the outside diameter (OD) of the tubing.
A2=Area of tubing using the inside Diameter (ID) of the tubing.
AT =Area of total profile of tubing.
PI = 3.1416. PI is a mathematical constant whose value is the ratio of any circle's circumference to its diameter
R = Radius of a circle
Density of Mild Steel = .2833 lbs./in³
Density of Chromoly = .2833 lbs./in³
V = Volume
W= Weight
MILD STEEL ROLL CAGE TUBING
Roll cage tubing in MS is 1.625" in diameter, and has a wall thickness of .134".
OD = 1.625"
ID = 1.625-(2*.134")
= 1.357"
1. A1 = PI*R²
=(3.1416)(1.625/2)²
=(3.1416)(.8125)²
=(3.1416)(.660015625)
= 2.074in²
2. A2 = PI*R²
=(3.1416)(1.357/2)²
=(3.1416)(.6785)²
=(3.1416)(0.46036225)
= 1.446in²
3. AT =A1-A2
=2.074-1.446
= .628in²
4. V = AT * Length of tubing.
= .628in² * 1.00in
= .628in³
5. W = V * Density
= (.628in³)(.2833lbs./in³)
= .178lbs.
So, the weight of Mild Steel Roll Cage tubing is .178lbs. for every inch of tubing.
CHROMOLY ROLL CAGE TUBING
Roll cage tubing in chromo is 1.625" in diameter, and has a wall thickness of .083".
OD = 1.625"
ID = 1.625-(2*.083")
= 1.459"
1. A1 = PI*R²
=(3.1416)(1.625/2)²
=(3.1416)(.8125)²
= 2.074in²
2. A2 = PI*R²
=(3.1416)(1.459/2)²
=(3.1416)(.7295)²
=(3.1416)(0.5321705)
= 1.672in²
3. AT =A1-A2
=2.074-1.672
= .402in²
= .402in² * 1.00in
= .402in³
5. W = V * Density
= (.402in³)(.2833lbs./in³)
= .114lbs.
So, the weight of Chromoly Roll Cage tubing is .114lbs. for every inch of tubing.
THIS WORKS OUT TO A 36% WEIGHT SAVINGS
SO, now that we know the weight per inch, how much is the weight difference between a MS roll cage, and a Chromoly Roll cage in the same car?
Let's Assume we will be using 740" of tubing in this example, based off of my Valiant.
Total weight using a mild steel cage = 740" * .178lbs.
This gives us 132lbs.
Total Weight using a Chromoly cage = 740" * .114lbs.
This gives us 84lbs.
Now, The 740" is a very rough measurement. I suggest you go out to your car, and do some measuring. Figure out how many inches your cage will be, then multiply that by .114lbs. for chromoly, and .178lbs. for Mild steel, and see what you come up with.
Please feel free to check my math too, I am human.
-Kenny
Re: 12 point roll cage weight [Re: StrokerAspen] #1076824
09/18/11 04:50 PM
09/18/11 04:50 PM
Renton Washington
Triple Threat Offline
Renton Washington
Cheap MS bar or cage, MIG welded is cheap. That's because welded tube is cheap DOM mild steel is almost as expensive as moly. I can definitely see how a 4130 Moly Bar that must be TIG welded can be 3 times the price. But its lighter, stronger and TIG welds look a lot nicer.
FWIW Mine is Moly. Do it once, and do it right.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 12 point roll cage weight [Re: Triple Threat] #1076825
09/18/11 05:04 PM
09/18/11 05:04 PM
Alberta Canada
Alberta Canada
I guess it just depends on who your fabricator is. I asked my chassis guy before I bought the cage kit. He said, it would cost me the same for fabrication, maybe less for chromo because HE prefers to TIG over MIG. In fact, he probably would have TIG'd the MS cage if I bought a MS cage kit.
Also, one other thing that seems to get over looked if your buying a kit, A cheaper kit, will most likely cost you more on the fabrication. I have seen Competition Engineering kits show up, and the main hoop is too wide to even fit in the car! Their kits are cheaper, but you get what you pay for.
I have heard S&W builds nice kits too, but I have no first hand experience with them. Art Morrison was closer to me, so shipping was cheaper.
-Kenny
Re: 12 point roll cage weight [Re: StrokerAspen] #1076826
09/18/11 06:03 PM
09/18/11 06:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
-Kenny
I pretty much tig everything... I normally wont even
do a mild steel cage... just picking up a mild steel
main hoop was heavy vs moly... I am putting in a
mild steel 8 point but I'm going to tig it because
the interior is still in it(no splatter)
Re: 12 point roll cage weight [Re: StrokerAspen] #1076827
09/18/11 06:49 PM
09/18/11 06:49 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Math looks good to me.
Re: 12 point roll cage weight [Re: MR_P_BODY] #1076828
09/18/11 06:55 PM
09/18/11 06:55 PM
Alberta Canada
Alberta Canada
NO SPLATTER is a great point too! The only thing I took out of my car to put a 10 point in, was my two front seats and my back seat. I rolled the carpet up into a ball in the middle. No splatter anywhere After the cage was done, the back seat, and front seats just bolted into place. The rear seat took some "gentle persuasion" to get it back in.
-Kenny
Re: 12 point roll cage weight [Re: StrokerAspen] #1076829
09/18/11 07:05 PM
09/18/11 07:05 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
When I priced out tubing for my RoadRunner, it was almost double for CM over DOM. I know others will say it's bunk, but around here I could not find it any cheaper. Most steel places didn't even want to bother looking for it as it's not worth the time for a small amount. Most chassis shops buy in bulk at 2-3000 ft at a time. The 50# savings wasn't worth the extra money for ME. As far as resale, I don't sell anything so that wasn't a issue.
Jeff
69 GTX 68 Road Runner
Re: 12 point roll cage weight [Re: ALKYW5DART] #1076830
09/18/11 07:57 PM
09/18/11 07:57 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
This was brought up at the "For A-bodies Only" website also. I voiced my opinion there, but I think "jericogtx" pretty much explained most hobbyists view..........
Re: 12 point roll cage weight [Re: hemicop] #1076831
09/18/11 08:07 PM
09/18/11 08:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I myself wouldnt even think of mild steel... everyone
wants light weight but they dont like to pay for it...
I just got done building a moly chassis for my street rod
EDIT
Most racers would kill to loose 65#... they'll buy
a glass hood and a glass bumper... those 2 items cost
more than the difference in the tubing and I'm not
sure you would come up with 65#
Re: 12 point roll cage weight [Re: hemicop] #1076832
09/18/11 08:51 PM
09/18/11 08:51 PM
Alberta Canada
Alberta Canada
Yeah, I figured if I was going to take the time to do the math, I would share it over there to.
It is a topic that always seems to pop up, and no one ever seems to put concrete numbers behind the topic. Looking at the kits on Art Morrison's website, yeah the chromo is 2x the price of the same MS kit.
That being said, it is only $320 more. Shipping is cheaper too. The price of an installed MS cage can vary more that $320 from chassis shop to chassis shop. MR. P has a good point too. I just spent over $300 for a set of fiberglass bumpers which saved me 50lbs.
There is nothing wrong with a MS cage either, I just don't like seeing chromo getting shot down from a cost point of view when the cost difference isn't as huge as most people make it out be.
Re: 12 point roll cage weight [Re: StrokerAspen] #1076833
09/19/11 02:01 PM
09/19/11 02:01 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
Oh, the cost of the CM isn't what gets you. Locally it's the price to weld it! Most shops around here think they're welding titanium so they jack the price up accordingly. My shop literally DOUBLED the price of my cage 'cause I wanted CM. Sorry, for a dual purpose car I just can't justify the expense even if would have been only a few hundred bucks more.
Re: 12 point roll cage weight [Re: hemicop] #1076834
09/20/11 07:42 PM
09/20/11 07:42 PM
Visalia Ca
P
prostreet68 Offline
prostreet68  Offline
P
Visalia Ca
When I did the cage in my 68 Dart I used MS DOM 1 5/8" x.134 wall. It was nearly $3 per ft. I bought the bender and bent all the tubes myself and then my son did the Mig welding because we didnt have a tig machine.
I cant tell you how much I have in the cage because we did ALL the labor.
Re: 12 point roll cage weight [Re: prostreet68] #1076835
09/20/11 08:30 PM
09/20/11 08:30 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I will never do a car in mild steel again the looks,weight,cert,and resale is a no brainer for me,but may not be right for every one.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
