Another good reason to check things,.....
#1076784
09/17/11 10:31 PM
09/17/11 10:31 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I just came in from the shop,...frustrated! ![](/ubbthreads/images/graemlins/puke.gif) I am freshening a 440 that somone else built,and will have it on the dyno in a couple of weeks. I bought a different camshaft and timing set to go with it,thinking I will see some decent gains with the cam swap. The old camshaft/timing setup was installed dot to dot,and checked in at 6 degrees advanced which is where it's recommended installed centerline is. I mocked up the new camshaft/timing set to see where everything needs to be,so it is easier once I get it on the dyno to make a back to back test. It was 20 degrees retarded when lined up dot to dot!! I had to check my work three times because I could not believe it! Advancing the timing set 8 degrees brought it exactly 8 degrees closer,so now only 12 degrees retarded! And some people say lining up the dots is close enough?????? ALWAYS check the installed centerline!!! I can't imagine how poorly this would have ran if it was put together that way. I will have to try another timing set and see if the "dot" on the cam gear was in the wrong spot,or if it is the camshaft itself. Keith
Re: Another good reason to check things,.....
[Re: Dunnuck Racing]
#1076785
09/17/11 10:41 PM
09/17/11 10:41 PM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
Anything made by us mere mortals can be screwed up or we can screw it up even if we didn't make it. ![](/ubbthreads/images/graemlins/laugh2.gif)
#1076786
09/17/11 11:39 PM
09/17/11 11:39 PM
Posts: 2,091 Delray beach, Florida
Performance Only
being 20 degree's off sounds more like your off 1 tooth. advance the cam 1 tooth and you'll have enough to be within the amount the timing set will correct.
machine shop owner and engine builder
#1076787
09/17/11 11:54 PM
09/17/11 11:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
When I first built mine 340 the cam key way was off 27*... I did the dot to dot to get a base line and couldnt understand why the valve was hitting the piston... the cam worked fine once I degreed it but forget that dot to dot stuff... like you said I dont know how some guys do the dot to dot and call it good ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Performance Only]
#1076788
09/18/11 12:01 AM
09/18/11 12:01 AM
Dunnuck Racing
Northern Indiana
Kind of figured they just missed it by a tooth when they marked it,just trying to warn people. I never run them with just lining up the dots,but you have to start somewhere. ![](/ubbthreads/images/graemlins/thumbs.gif) Keith
#1076789
09/18/11 12:05 AM
09/18/11 12:05 AM
MR_P_BODY
Keith
I dont even have dots... I set the intake lifter on the max lift then set the crank to the degree its suppose to be then slide my gears on then check again ![](/ubbthreads/images/graemlins/wave.gif)
#1076790
09/18/11 12:18 AM
09/18/11 12:18 AM
Posts: 7,506 Az
Crizila
Az
That's amazing ( if it aint off a tooth ). I always degree in my motors, using the dots as a starting point. Never found one off more than 2 degrees, and most are dead on. Just did my 5th Hughes cam last week. All were dead nuts on.
Fastest 300
#1076792
09/18/11 10:20 AM
09/18/11 10:20 AM
Posts: 16,932 NC
440Jim
NC
Yes, always check the cam installed centerline position. One tooth off on the timing set is about 12-14 degrees.
I have seen cams marked/ground right on, 2,4, and even 9 degrees off from the recommended installed position (typically 4 degrees advanced from LSA). And all those were with the same timing set, block, crank, etc.
