Another good reason to check things,.....
#1076784
09/17/11 10:31 PM
09/17/11 10:31 PM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I just came in from the shop,...frustrated! I am freshening a 440 that somone else built,and will have it on the dyno in a couple of weeks. I bought a different camshaft and timing set to go with it,thinking I will see some decent gains with the cam swap. The old camshaft/timing setup was installed dot to dot,and checked in at 6 degrees advanced which is where it's recommended installed centerline is. I mocked up the new camshaft/timing set to see where everything needs to be,so it is easier once I get it on the dyno to make a back to back test. It was 20 degrees retarded when lined up dot to dot!! I had to check my work three times because I could not believe it! Advancing the timing set 8 degrees brought it exactly 8 degrees closer,so now only 12 degrees retarded! And some people say lining up the dots is close enough?????? ALWAYS check the installed centerline!!! I can't imagine how poorly this would have ran if it was put together that way. I will have to try another timing set and see if the "dot" on the cam gear was in the wrong spot,or if it is the camshaft itself. Keith
Re: Another good reason to check things,.....
[Re: Dunnuck Racing]
#1076785
09/17/11 10:41 PM
09/17/11 10:41 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
Anything made by us mere mortals can be screwed up or we can screw it up even if we didn't make it.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
#1076786
09/17/11 11:39 PM
09/17/11 11:39 PM
Posts: 2,091 Delray beach, Florida
Performance Only
being 20 degree's off sounds more like your off 1 tooth. advance the cam 1 tooth and you'll have enough to be within the amount the timing set will correct.
machine shop owner and engine builder
#1076787
09/17/11 11:54 PM
09/17/11 11:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
When I first built mine 340 the cam key way was off 27*... I did the dot to dot to get a base line and couldnt understand why the valve was hitting the piston... the cam worked fine once I degreed it but forget that dot to dot stuff... like you said I dont know how some guys do the dot to dot and call it good
[Re: Performance Only]
#1076788
09/18/11 12:01 AM
09/18/11 12:01 AM
Dunnuck Racing
Northern Indiana
Kind of figured they just missed it by a tooth when they marked it,just trying to warn people. I never run them with just lining up the dots,but you have to start somewhere. Keith
#1076789
09/18/11 12:05 AM
09/18/11 12:05 AM
MR_P_BODY
Keith
I dont even have dots... I set the intake lifter on the max lift then set the crank to the degree its suppose to be then slide my gears on then check again
#1076790
09/18/11 12:18 AM
09/18/11 12:18 AM
Posts: 7,506 Az
Crizila
Az
That's amazing ( if it aint off a tooth ). I always degree in my motors, using the dots as a starting point. Never found one off more than 2 degrees, and most are dead on. Just did my 5th Hughes cam last week. All were dead nuts on.
Fastest 300
#1076792
09/18/11 10:20 AM
09/18/11 10:20 AM
Posts: 16,923 NC
440Jim
NC
Yes, always check the cam installed centerline position. One tooth off on the timing set is about 12-14 degrees.
I have seen cams marked/ground right on, 2,4, and even 9 degrees off from the recommended installed position (typically 4 degrees advanced from LSA). And all those were with the same timing set, block, crank, etc.
