torque converter balance??? #1076673
09/17/11 04:14 PM
09/17/11 04:14 PM
scratchnfotraction Offline OP
I have a 78 cast crank 440 with a 727
and just got another 727 from a 400
the 400 TC is smaller and has a weight on it like my cast crank 440 TC does.
they look the same exept the size, but thought i would ask if they will swap.
will the weighted 400 TC work behind the cast crank 440?
TIA
Re: torque converter balance??? [Re: scratchnfotraction] #1076674
09/17/11 06:03 PM
09/17/11 06:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
All cast crank big blocks (383, 400, 440) use the same amount of converter weight (100 grams). Some have a single large triangular weight and some have two smaller rectangular weights.
Re: torque converter balance??? [Re: John_Kunkel] #1076675
09/17/11 07:58 PM
09/17/11 07:58 PM
THANK YOU! John
I will use the TC that came with the trans then.
