604 build. #1076300
09/17/11 07:42 AM
09/17/11 07:42 AM
A shed in England
Tig Offline OP
Tig  Offline OP
A shed in England
Hi.
Is it possible to build a 4.75 stroke 4.50 bore 604 motor in a non raised cam block?
Would steel rods, 2.20 journal help?
TIA.
Re: 604 build. [Re: Tig] #1076301
09/17/11 08:00 AM
09/17/11 08:00 AM
pa
572charger Offline
572charger  Offline
pa
yes mine is a 2003 mopar siamese block with oliver 2.2 big end rods , only grinding for clearance was at the internal oil pick up ![ i use external raybarton oil system] comp roller cam 720 lift no clearance problems
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: 604 build. [Re: 572charger] #1076302
09/17/11 10:03 PM
09/17/11 10:03 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
How about a Hemi head motor, will the cam clear the rods? Dave
