3rd Outing, Not Happy #1076263
09/17/11 02:10 AM
09/17/11 02:10 AM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Took the 68` to Quaker tonight,and had fixed a few issues.
Really expected to get an 11` out of it,but was`nt meant to be.
Main issue fixed was fuel. I have added a blue-Holley at the tank pushing into the Carter 120 mech. pump.
Also found the fuel-pressure gauge was inaccurate. Showed 2-lbs more pressure than there really was. Would drop to 6 {actually 4} Now a steady 7-lbs at all speeds.
Well car didn`t like something,air was KILLER tonight and I actually went slower.
1st pass 12.11@109. Previous best was 12.22,but the conditions were 2-3 tenths FASTER.
Jetted up went 12.34,jetted down went 12.31.
Final run I bumped the timing to 35{was32} and it picked up mph to 110.87,but e.t. was 12.20.
Does`nt like to rev past 5,000 no matter what I have done so far. Springs are plenty for the small hyd. cam in it. Lifters have .007 pre-load.
Not sure where to go next.
Tires are shot,so its probably done till next summer.
At least now I have something think about while I`m shoveling snow
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: 3rd Outing, Not Happy [Re: 6bblFLASH] #1076264
09/17/11 08:12 AM
09/17/11 08:12 AM
gregsdart Offline
gregsdart  Offline
How much gap do you run in the plugs? You can drop down to .025 and see if the car picks up. This will show if the spark is weak, but may not uncover other ignition ills. Have you tried a new ignition, hard wired out side of the old harness? I have seen the old harnesses hide a bad connection problem till a buddy of mine didn't have any hair left.
Re: 3rd Outing, Not Happy [Re: gregsdart] #1076265
09/17/11 08:23 AM
09/17/11 08:23 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Boosted engines need stronger springs then what the cam calls for.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 3rd Outing, Not Happy [Re: 1967dartgt] #1076266
09/17/11 09:11 AM
09/17/11 09:11 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
may not have the right cam for boosted engines...also depends on the amount of boost..
boosted engines love ignition ..
I have my initial at 18* and all in at 3,000rpm @ 36*..you can bump that up a few...good race gas realy makes them come alive.(I know, no brainer)
need to check your carb, blowers need the gas to keep them cool..I run mine on the rich side..92's on the secondaries and 90's on the primaries..
so what if its a SB Chevy...its still an engine ..
where I got most of my info for base line was from Gary Dyer...
Re: 3rd Outing, Not Happy [Re: smokinwoody] #1076267
09/17/11 10:24 AM
09/17/11 10:24 AM
gregsdart Offline
gregsdart  Offline
"boosted engines love ignition"
Jeff, this motor may need less, I'm almost sure of it. My 06 GT running 7 psi is down around 17 degrees at full boost, runs like a scalded cat!
It surely wouldn't hurt to reduce plug gap to .025, back timing down to 28, and see what happens.
Re: 3rd Outing, Not Happy [Re: gregsdart] #1076268
09/17/11 10:52 AM
09/17/11 10:52 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
it doesn't hurt to try....wouldn't compression come into play along with cam timing and fuel...
I guess I'm too old school..LOL
I only know what works for me...
Re: 3rd Outing, Not Happy [Re: gregsdart] #1076269
09/17/11 11:05 AM
09/17/11 11:05 AM
N.E. Ohio
N.E. Ohio
Thanks for the input. Yeah the igniton is a possibility too.
Resistance to RPM is puzzling,I should have a hard time keeping up with it.
Pulls hard at the hit then flat-lines.
It makes 5-lbs boost.
The best it ever ran was its first day out at the Mopar Nats.
I had cooling issues and was leaving the line at 180ish.
jetting was 82/88 {78/88std} only the mech. pump and only 4-lbs. fuel pressure.
It ran [Email]12.22@111[/Email] with poor traction in hotter weather --80`s.
Last 2 times out it was maybe 70,and last night it was 55*.
Cooling has been sorted out and added fuel-pump and jetting since it rattled the valves on the last pass the 2nd time out.
Ran it ALOT on the street and all was well.
Looking back,it actually seems like its too cold???
Maybe I`m way rich yet?
Not sure what thats telling me,,,,yet?
Re: 3rd Outing, Not Happy [Re: gregsdart] #1076270
09/17/11 11:34 AM
09/17/11 11:34 AM
NE OHIO
SRT440DUSTER Offline
NE OHIO
Its not uncommon for boost to blow out the spark at higher rpms because of a wide gap. Have you done a compression check? What r the cam specs? Also a great Idea to have a wideband 02 on it. Guessing if your rich or lean will get old quick.
Re: 3rd Outing, Not Happy [Re: 6bblFLASH] #1076271
09/17/11 11:35 AM
09/17/11 11:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What needle and seats are you running... a .110 is
in a stock holley... I would go up on them... .120 or .130
any boosted engine I've worked on wanted less timing
as boost/pressure went up
Re: 3rd Outing, Not Happy [Re: MR_P_BODY] #1076272
09/17/11 12:03 PM
09/17/11 12:03 PM
N.E. Ohio
N.E. Ohio
It has .120 seats in it now.
I can only assume the colder dense air is causing detonation?
The car is REALLY quiet and I can`t hear anything.
But added timing improved MPH, how am I to interpret that?
Even more early and less as it builds boost?
The richer jetted runs gave the best 60.ft times. So it wants more squirter/volume.
110.87 is actually decent at Quaker,it goes uphill. That would be like 113 or so at Norwalk.
Leaves good 1.68 -60ft. leaving at idle,tries to finish good. Sluggish in middle.
The carb is a "chinese" knock-off proform I bought from CRT at a swapmeet.
I wish I could throw on a "good" carb to form a baseline comparison..
Re: 3rd Outing, Not Happy [Re: 6bblFLASH] #1076273
09/17/11 12:09 PM
09/17/11 12:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Squirter are usually the 60' so it wants more fuel
on the launch and might need less down track(jets)
EDIT
Also if you are leaving at no boost the engine is
still a N/A engine at that point so it would like
like the timing but as boost starts you need to pull
timing(need a boost/timing controller)
Re: 3rd Outing, Not Happy [Re: 6bblFLASH] #1076274
09/17/11 12:20 PM
09/17/11 12:20 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
With boost always work with a known good carb and adequate fuel pressure. The conseqses of going lean under boost can be devastating to the bottom end.
Sounds a bit like the boost may be "blowing out the candles" above 3K or so....I assume your timing is 'all in' regardless so on a 1/4 mile run if the total is right it's not going to make too much difference. I think when I had that blower I ran no more than 32-34. A more efficient 9 1/2 (but still relatively tight) converter would pull harder all the way through.
I ran it with just a Chrome box and a blaster 2, if I had it now I'd probably run the FBO box and coil and have them recurve the dizz for about 12-14 initial and a realtively slow centrifugal 18-20 degree advance to 2800-3000.
Did you do a good valve job on the heads? I ran just cleaned up 906's with 2.08" and 1.81 exhausts with a sharp Serdi on them.
WIZE
In Car:
Re: 3rd Outing, Not Happy [Re: Streetwize] #1076275
09/17/11 12:43 PM
09/17/11 12:43 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
whats the static compression..
I think ..this is my opinion...you don't have the right cam to effectively use boost...
there I said it...
Re: 3rd Outing, Not Happy [Re: smokinwoody] #1076276
09/17/11 03:30 PM
09/17/11 03:30 PM
N.E. Ohio
N.E. Ohio
there I said it...
Cam is Summit #-6401 .465/.488 lift,224/234@.050/282/292 adv. 114-c/l.This cam was recommended by several users,and was 62-bucks.
Installed at 109-straight-up. Springs are MP "510" springs
Compression is 8.69,heads pocket-ported "250" iron heads{same as 906`s}
Stock 68` rotating assembly in 66` block.
carb is 850,proform copy. Came with 78/84 jets.
boost referenced power-valve.
1-7/8th headers,2-1/2 exhaust with X-pipe.
Stock conv.3.55 rear.est. weight 3,700 something w/driver.
Re: 3rd Outing, Not Happy [Re: 6bblFLASH] #1076277
09/17/11 03:41 PM
09/17/11 03:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
there I said it...
Hate to tell you this but MP are JUNK... I ran a set
the first year I built my car... they said good for
.640.... well after the engine didnt work like I
figured I checked the pressures on the springs...
I was in valve float as soon as I left the line...
and the springs measured #65 on seat... so did the
new springs (same ones).... you better check the
spring pressure
Also you have the cam in 5* advanced(which is fine)
Re: 3rd Outing, Not Happy [Re: MR_P_BODY] #1076278
09/17/11 07:04 PM
09/17/11 07:04 PM
N.E. Ohio
N.E. Ohio
"You also have the cam in 5* advanced...which is fine".
Cam card said 109* ATDC-intake,so thats where I put it.
Where did I figure wrong.
After thinking over all the input, I am leaning towards the ignition. Better air and more fuel taxes the ignition more.
Valve springs would`nt care about the weather,only RPM.
I have a chrome-box,don`t they wire different than the orange?
Going to check all the voltages at the the coil,resistor etc.... too.
Re: 3rd Outing, Not Happy [Re: 6bblFLASH] #1076279
09/17/11 07:30 PM
09/17/11 07:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If it was straight up it would be at 114 but you
did what the cam card suggested for which is fine
Re: 3rd Outing, Not Happy [Re: 6bblFLASH] #1076280
09/17/11 07:45 PM
09/17/11 07:45 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Your fuel system won't work like you have it.
Re: 3rd Outing, Not Happy [Re: Challenger 1] #1076281
09/17/11 10:26 PM
09/17/11 10:26 PM
N.E. Ohio
N.E. Ohio
Care too explain?
Re: 3rd Outing, Not Happy [Re: smokinwoody] #1076282
09/18/11 09:14 PM
09/18/11 09:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I can tell you from my experience it hurt to try.
3 sets of pistons, and a few sets of head gaskets. Backed my total timing to 29 degrees leaned the carbs back to stock. Lost no performance. Same set of pistons in the motor since 1991. 340+.030",8-1,240@.050"/.540",home ported stock heads,Dyers 6V-71 on a single 4 barrel intake, 3880lbs. This weekend at Norwalk It went 11.01@121.96 thru the mufflers.
Doug
