Power to manual steering adapter #107598
08/20/08 12:18 AM
08/20/08 12:18 AM
OH
Lynch Rd Runner Offline OP
OH
Where can I get a good priced power to manual steering box adapter???? Thanks Troy
1964 Crown Coupe 1964 330 Dodge Wagon
Re: Power to manual steering adapter [Re: Lynch Rd Runner] #107599
08/20/08 12:28 AM
08/20/08 12:28 AM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
Flaming River or Borgensen have some nice pieces that will do the trick for you. Mine is a weld on unit I purchased form a neighborhood race car shop.
Joey Lemire
Re: Power to manual steering adapter [Re: jake4cars] #107600
08/20/08 01:32 AM
08/20/08 01:32 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Mine is from Firm Feel and it just slides on the manual box and onto the P/S shaft. Ron
Re: Power to manual steering adapter [Re: Lynch Rd Runner] #107601
08/20/08 01:38 AM
08/20/08 01:38 AM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
Schoemaker (spelling?); the folks who make the engine swap kits; made the one on my car, I saw the Mopar Performance catalog is listing one, also.
Re: Power to manual steering adapter [Re: Lynch Rd Runner] #107602
08/20/08 07:58 AM
08/20/08 07:58 AM
PA
moparboy66 Offline
moparboy66  Offline
PA
I used the one from Mancini Racing. I think it was around $ 120 , well machined with an indexing slot, and it fit perfectly, locking in place with two roll pins.
Re: Power to manual steering adapter [Re: moparboy66] #107603
08/20/08 10:22 AM
08/20/08 10:22 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Mine is the OEM adapter from a B van, and looks just like that.
Re: Power to manual steering adapter [Re: ZIPPY] #107604
08/21/08 04:45 PM
08/21/08 04:45 PM
Pizza Bucket
snuggles Offline
snuggles  Offline
Pizza Bucket
mine also
Re: Power to manual steering adapter [Re: ZIPPY] #107605
08/21/08 04:48 PM
08/21/08 04:48 PM
Dexter, Michigan
copper67440 Offline
mopar addict
copper67440  Offline
mopar addict
Dexter, Michigan
I'm interested too. Do the dealers still have the "B" van piece?
Re: Power to manual steering adapter [Re: copper67440] #107606
08/21/08 07:44 PM
08/21/08 07:44 PM
can you use the shaft out of a manual steering column?
Re: Power to manual steering adapter [Re: Lynch Rd Runner] #107607
08/22/08 03:14 AM
08/22/08 03:14 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
Check first your adapter on the steering shaft. if that thing is worn out,
go and get the flaming river one. did the same,
steering, looking and quality is way better.
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: Power to manual steering adapter [Re: Den300] #107608
08/22/08 09:10 PM
08/22/08 09:10 PM
Ridley Park, Pa.
69MOPE Offline
super gas
69MOPE  Offline
super gas
Ridley Park, Pa.
I have an extra Faming River adaptor. PM me if interested.
Re: Power to manual steering adapter #107609
08/23/08 11:36 AM
08/23/08 11:36 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Yes. If you are comfortable with fabricating.
Cut and splice or cut and add. Index the pin and I'm pretty sure it's 3" difference.
Re: Power to manual steering adapter [Re: Magnum] #107610
06/20/11 08:47 PM
06/20/11 08:47 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Bingo...
Section 3" into your steering shaft or what I did was cut an end off a junker at the yard, manual or automatic.
and cut your old shaft where the new piece will give you 3 more inches
grind 45 chamfers on both sides to give the weld bead some room
remember to line up reference holes to keep wheel in somewhat of an alignment. Clamp in V blocks or whatever you have.
Tack one side and check alignment, tack again at 120 degrees, check again and then 3rd tack. If straight run the bead
Grind down slag, sand and paint to prevent flash rust. Done deal!
Rolled it and its straight as an arrow. Reassemble column with new longer shaft. Now It'll reach your manual box!
Re: Power to manual steering adapter #107611
06/20/11 11:58 PM
06/20/11 11:58 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Yes,I don't see why not. It worked for me.
Re: Power to manual steering adapter [Re: pishta] #107612
06/21/11 02:27 AM
06/21/11 02:27 AM
Long Island Ny
V
varlo Offline
varlo  Offline
V
Long Island Ny
Bingo...
Great work! I like your attention to detail it looks great.
