Re: Power to manual steering adapter
[Re: ZIPPY]
#107604
08/21/08 04:45 PM
08/21/08 04:45 PM
Posts: 8,964 Pizza Bucket
snuggles
Pizza Bucket
Mine is the OEM adapter from a B van, and looks just like that.
mine also
[Re: ZIPPY]
#107605
08/21/08 04:48 PM
08/21/08 04:48 PM
Posts: 819 Dexter, Michigan
copper67440
mopar addict
mopar addict
Dexter, Michigan
I'm interested too. Do the dealers still have the "B" van piece?
[Re: copper67440]
#107606
08/21/08 07:44 PM
08/21/08 07:44 PM
can you use the shaft out of a manual steering column?
[Re: Lynch Rd Runner]
#107607
08/22/08 03:14 AM
08/22/08 03:14 AM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
Check first your adapter on the steering shaft. if that thing is worn out, go and get the flaming river one. did the same, steering, looking and quality is way better.
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
[Re: Magnum]
#107610
06/20/11 08:47 PM
06/20/11 08:47 PM
Posts: 893 Tustin, CA
pishta
Tustin, CA
Yes. If you are comfortable with fabricating. Cut and splice or cut and add. Index the pin and I'm pretty sure it's 3" difference.
Bingo...
Section 3" into your steering shaft or what I did was cut an end off a junker at the yard, manual or automatic. and cut your old shaft where the new piece will give you 3 more inches grind 45 chamfers on both sides to give the weld bead some room remember to line up reference holes to keep wheel in somewhat of an alignment. Clamp in V blocks or whatever you have. Tack one side and check alignment, tack again at 120 degrees, check again and then 3rd tack. If straight run the bead Grind down slag, sand and paint to prevent flash rust. Done deal! Rolled it and its straight as an arrow. Reassemble column with new longer shaft. Now It'll reach your manual box!
#107611
06/20/11 11:58 PM
06/20/11 11:58 PM
Posts: 1,565 tennessee
pushbutton
tennessee
Yes,I don't see why not. It worked for me.
[Re: pishta]
#107612
06/21/11 02:27 AM
06/21/11 02:27 AM
Posts: 62 Long Island Ny
varlo
Long Island Ny
Bingo...
Great work! I like your attention to detail it looks great.
