Small Block heads and BIG Valves?! #1075919
09/16/11 11:16 AM
09/16/11 11:16 AM
Texas Afghanistan Iraq etc.
DakFink Offline OP
DakFink  Offline OP
What heads for a Small Block will accommodate a 2.21" intake valve, and actually have the runner volume to use it?
I think a W9 and W8 will.
Maybe Indy 360-1?
Any others?
Re: Small Block heads and BIG Valves?! [Re: DakFink] #1075920
09/16/11 02:45 PM
09/16/11 02:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What I have in the W-9 is a 2.18 with a 1.625... dont
know if you can go bigger... the margin between mine
is real close
Re: Small Block heads and BIG Valves?! [Re: MR_P_BODY] #1075921
09/16/11 03:08 PM
09/16/11 03:08 PM
Finland
mafo Offline
mafo  Offline
Finland
I have 2.25 intake valves and if I remember correctly 1.55 exhausts in my Nickens W8 s
my CFE heads have slightly smaller intakes, don t have my notes here now but maybe 2.225
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Small Block heads and BIG Valves?! [Re: mafo] #1075922
09/16/11 08:15 PM
09/16/11 08:15 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
My CFE W8's had 2.25" intake and a 1.55" exhaust. I think you can do this with any raw cast W7-9 head. You just have to give up some exhaust valve. With a 4.185" bore that is. If you are running 4.240+ you can run the big intake and still have room for a big exhaust valve.
It is very normal to find circle track heads with 2.200" intake valves and 1.625" exhaust. They still have a lot of meat int the ports too. To handle that boost.
Leon
Re: Small Block heads and BIG Valves?! [Re: Leon441] #1075923
09/17/11 12:26 AM
09/17/11 12:26 AM
DakFink Offline OP
DakFink  Offline OP
Thanks guys!!
Pretty much what I was thinking!! W8 & W9s will do it.
Was just curios if the Indy's or Brodix would.
The W9-RPs that I have now have 2.20" in the Int.; don't remember the exhaust.
I have a pair of Untouched regular W9's on the shelf, I was just brain storming about.
Using a formula I found for sizing Valves to the Bore diameter. Looked like this = 52% of bore size for intake valve and 72-73% of Int Valve size for Exhaust valve.
IF I had a bore of 2.250 which an R3-siamese will go out to. I would need 2.21" Int and 1.59-1.61" exhaust to fulfill that equation.
Guess I got too much time on my hands!!! LOL!!
