Z Bar disconected #1075886
09/16/11 04:02 AM
09/16/11 04:02 AM
edison, nj
challengeragtop Offline OP
edison, nj
As I'm trying to solve my overheating problem. I took the car out today and the Z bar fell off the connector attached to the body. Have not had a chance to get under and look at it. But what could cause this. Is there a clip to hold it in place. I just went to shift into 3rd gear and the pedal stayed on the floor. Looked under the hood and the Z bar had fallen off the the mount on the body. What should I be looking for to have caused this problem......Thanks for you're help
Re: Z Bar disconected [Re: challengeragtop] #1075887
09/16/11 06:54 AM
09/16/11 06:54 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
The retainer wire most likely broke or fell off. It holds the z-bar to the pivot ball on the frame.
http://www.brewersperformance.com/proddetail.asp?prod=TSW910
Re: Z Bar disconected [Re: Pntastar69] #1075888
09/16/11 10:29 AM
09/16/11 10:29 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
or worn or broken motor mounts
1969 Dodge Charger 1969 Dodge Superbee
