It's Finally Rolling
#1075605
09/15/11 04:37 PM
09/15/11 04:37 PM
Posts: 101 NC
1967Valiant
NC
Great Day Today!
Re: It's Fianlly Rolling
[Re: StrokedW7]
#1075617
09/15/11 11:18 PM
09/15/11 11:18 PM
Posts: 928 NC
SLOW67
NC
Why would anyone want to build one of those ugly cars?
Re: It's Finally Rolling
[Re: 1967Valiant]
#1075620
09/16/11 07:56 AM
09/16/11 07:56 AM
Posts: 101 NC
1967Valiant
NC
Ofcourse its a 1967 Valiant, Back Half with Dana 60 4.30 with Detroit locker, Moser 35 Spline's, 12 Point MS Cage, Alterkation Front end, Centerline Convo-Pros all the way around, Mikey Thompson Street rubber all the way around.
The cage is so visable because I took the picture from a upward angle out of the ditch.
The Engine is: 60 over 440 4.25 stroke 512CI About 10.5 to 1 Stealth CnC Heads PRW Stainless Steel Rockers Comp Street Solid Roller XR292R ARP Studs all the way around Stud Girdle with Billet main Caps Charlies pan with swing pick up and external oil Intake is Mopar M1 with a Spacer Carb is a 1100 CFM SV1 Firecore Dist with Digtal 6AL2 and HVC2 coil Custom 3 step headers 100 shot of plate nitrous
Transmisson Powerglide with JW Bell 180 Straight Cut Trans Brake Gearvendors OD 9 5/8 converter stall about 3800 to 4200
Putting a Racepak street dash in it.
Ok theres the run down opinions would be apped esp est et etc. Also for those that have one what does your weigh with a bigblock in it etc.
Ok that all for now still have about a year left in build so hope it goes well, Because I am already about broke lol
Cheer's
[Re: 1967Valiant]
#1075621
09/16/11 08:33 AM
09/16/11 08:33 AM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
My Valiant is 3,150lbs with an iron head 440/727, Dana and ladder bars, 10 pt mild steel cage, 73 style disc brakes, Aerospace discs on the Dana, full interior with race buckets. It was 2,940 with a 360 and 8 3/4 with 11" drums.
[Re: 1967Valiant]
#1075623
09/16/11 10:28 AM
09/16/11 10:28 AM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
3291# with driver and 5 gallons gas. 440/727 Dana Aluminum heads FULL interior/carpet 8 pt bar all original window glass fiberglass hood only
If you like drag racing, support your local track.
[Re: 1967Valiant]
#1075624
09/16/11 10:44 AM
09/16/11 10:44 AM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Mine was 3470 with my lead bottom in it and a 511" B1 powerglide combo on a small tire.
